Just wondering if anyone has a say on the Return Flow type FMIC that are popping up all over the place?
I have been searching around for a decent sized FMIC without going over the top and these have caught my eye due to the fact of no need to cut my REO bar or any other nasty holes in my baby.
Only problems I can see with them at a glance is the fact the return pipe sits VERY low and that nasty bend they often have towards the end of the return pipe. And possibly the sharp change of direction for the air to have to go back towards the turbo.
Just incase I didnt explain it well enough heres a pic of the kit im interested in.
Anyone got some more info on these?
Hi DD i have Blitz kit fitted to S2 Stagea ,you will need to MOD REO but only a small mod ,i had to FOLD 50 mm strip along REO to miss COOLER,i taped the REO marked 50mm on END`S 15mm in middle,then SLOTTED with Hacksaw & the FOLDED it UP,Pic`s here to help, hope this is a HELP cheer`s Chuckie.
post-36964-1267420100_thumb.jpgpost-36964-1267420158_thumb.jpgpost-36964-1267420258_thumb.jpgpost-36964-1267420643_thumb.jpg
  • Replies 40
Thats for the extra info and pictures Chuckie, very clean install btw.
Thank`s DD i did do some other mod`s to my fitup,
i changed my PIPE`S to same as standard & chopped the bottom fitting so i would keep all stock undertray fitting well i shall take a few more PIC`S & remove REO again & take Pic`s of all bit`s & post up so may be of HELP to someone,but it`s a Good COOLER iam happy with it ,Cheer`s Chuckie.
Thanks mate, I hadn't seen that :)
Unfortunately confirms that I had my test fit correct and 50mm of reo does indeed need to be removed which I think might be too costly in terms of having an insurance claim voided
Talbo you don`t need to REMOVE IT , Just FOLD IT UP then you should be ok ,this is a WORRY for most as they don`t want any hassle`s with INSURANCE COMPANIES,as long as it`s still there you don`t loss any thing,& REALLY with it FOLDED UP may ADD a bit of STRENGHT in steed of LOSING IT ,
GOOD LUCK ,
Cheer`s Chuckie.
Has anyone put one of these on a S1 or S1.5 R33, Did you have to take a 50mm section of the reo bar out?
If anyone has the R33 blitz instructions, is it possible to get me a scan? Thanks in advance
I think i actually do have a Blitz Instruction book, but i believe its in Japanese. Ill take a peek and post it up anyway if you want.
That's cool guys. At the moment I'm thinking I'm probably going to sell the blitz lm..... just don't feel comfortable taking that much out of the reo and risking an insurance void. Will look at other options like a custom narrow core or I don't fkn know let yet lol :down:
Not worried about power since I know that beautiful Blitz would flow more than what a RB20 would ever make, just trying to find out info about them from anyone who has one.
Response is all Im after at the end of the day, and Im leaning towards the Blitz ATM due to the fact its only $780 and its Blitz so you know its quality. Or a HPI kit of the same style.
HPI is just china gear with a jap twist :)
lol at ARC prices, they will have same power levels as fmic with loads more response.
Cheaper alternative is the 34 smic theyre good for the power your asking and flow very well. They use 80mm core, i have used them with 220-230 and been very happy compared to my fmic setups.
Both junk, ignore these recomendations. They are heat soak kings. TBH there is no WAY IN HELL they support a consistent safe 220-230rwkw, we've proved how poor they are on numerous occasions. Their turn flow FMIC kits are magic though.
Yer I had one of these Blitz CS installed on my 1.5 - I had my way with the front bar and the angle grinder but I got there in the end. Significant little chunk out of the REO bar too, but really, if you cut it right and spray the thing black it's barely noticeable. The series 1.5 is good at hiding this too. Series 1.5 front bar also sits lower than the other R33 front bars, so the return pipe sat quite flush. The cooler itself looked a treat...matches very well with the car body as many series 1.5 are the light bluey-silver colour.
My only problem with all these return flow kits: the top brackets never line up 100%...forcing you to make your own top bracket. I don't know how they didn't get this right. It's like every return flow manufacturer has been going off the same incorrect template or something. I mean, they don't seem to be customised towards R33 or R34. Only one I've seen that fits straight up is ARC.
Noticeable difference in response going from side mount to front mount return flow - can probably reduce the effects with a bit of tuning. For what it's worth, on stock boost (7psi?) my car made 165.5rwkw with this cooler and a 3" turbo-back on a very conservative dyno (everyone else reported lower than normal readings for their vehicles on the day).
funny ive installed maybe 20 (most likely more) and never had an issue with the top bracket, in fact the blitz kit has always come with different r33 and r34 brackets included... even pictured in the instructions.
Id suggest reading them next time you do an install.
The only kits ive found to be out are the cheaper JJR kits but for the saving 5mins of work is no biggie.
I did read the instructions (except for the bits written in Japanese) and tried it in many ways...including with both R33 and R34 brackets which came with the kit. Have you installed on a series 1.5? I don't see how it should make a difference but perhaps the part of the chassis where the top bracket is supposed to bolt on is in a different position. Either that or my car has had a front ender to knock it out of allignment. The cooler is sitting flush with the rest of the car too, i.e. straight and dead centre...it's only this top bracket mounting point that is out.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
