Hey Guys
im the proud new owner of a NM35
thanks for the website its overloaded with lots of good info but due to there being so much im finding it hard to find some answers
have a few questions...
whats the difference between NM35 and M35?
will the engine share the same oil filter as a 350z? or can anyone quote the ryco part number?
also is there an M35 parts specific page? having trouble finding it
picking the car up tomoz and think i will change the oil as am going away over the long weekend with the new car and wouldnt mind knowing the oil and filter is fresh.
thanks
Edited by garetb16
https://www.sau.com.au/forums/topic/310156-new-nm35-owner/
Hey Guys
thanks
Some answers for your
NM35 = 4WD M35 = 2WD
not sure about the oil filter part (never looked sorry)
Oil capacity is 4.7L
Cheers
Andy
https://www.sau.com.au/forums/topic/310156-new-nm35-owner/#findComment-5110748
what are the 3 functions of the 4wd/diff control switch?
i know it says snow and stuff but whats the best function for different styles of driving?
or what does each function do?
Snow = low boost and power split 50/50 front to rear to 40kph.
Sncro = split 50/50 front to rear to 40kph.
Middle = full ATTESA mode. mostly rear till slip or lateral G detected and power sent to front wheels
https://www.sau.com.au/forums/topic/310156-new-nm35-owner/#findComment-5111462
ok cool.
so snow isnt really needed for Australian conditions.
SNCRO: 50/50 all the time.
Middle: Attessa (prob best for all sorts of driving)
if you were going for a "spirited drive" for example would you go Sncro? or just leave it.?
https://www.sau.com.au/forums/topic/310156-new-nm35-owner/#findComment-5112204
Some very good info is available here:
http://en.wikipedia.org/wiki/ATTESA
Refer to the ATTESA-ETS section.
In general its best to leave it in the middle position, but if you're driving on some really slippery surface where you need a bit more help from the AWD, you can put it in 50-50 "synchro" mode. Its not usually necessary for normal driving however, even on very wet roads...
https://www.sau.com.au/forums/topic/310156-new-nm35-owner/#findComment-5112351
True, BUT if you are driving on a winding gravel road "synchro" is fantastic :)
Edited by iamhe77
https://www.sau.com.au/forums/topic/310156-new-nm35-owner/#findComment-5112616
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
