Hi All
im planning on buying a set of the gtc's and just wondering what you guys think about the wheel size and if it will fit on my r33 perfectly.
18x9+24 Front
18x10+24 Rear
Im not sure what tyre size should i get. Will a wide tyre fit in the rears without adjusting the camber or rolling the fenders? What set up will be perfect for to fit for my r33?
If any has the same wheel size or similar set up can you please post a pic?
Thanks heaps.
https://www.sau.com.au/forums/topic/310388-volk-gtcs/
will fit nicely, the 10's will be a tight fit with a big tyre you'll get a 265 with a roll of guards you will need to run some camber as it will be a bit mexican but depending how low wll depend how much camber. front should fit up without any dramas, depends how low you want to sit.
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5113224
Hi
Yeah thanks for the reply. Say if i have a smaller tyre size in the rear you reckon it'll fit nicely? Well my car isnt that low only 2 finger space front the guard with my current rims. I can always adjust the height cos i can adjust my suspension.
I also have another question, what is the lowest tyre size for the 10's?
Thanks for the help
Edited by honkie
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5113555
265/35R18s all around on my GTCs, on my 33
Hey there
Did you have to do any camber adjustments and rolling your guards? Can u post a pic of your gtc just to show me how it looks like? I want to know how will it look like =]
Cheers mate much appreciated.
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5114159
Hey there
car come with the wheels on it, i dont think the guards have been rolled.
if you need better pics let me know and ill take some
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5114947
Hey there
Looks nice man.. Yeah can you take a closer picture of the wheels on the side. cos i want to see how much it comes out from the guard or how close it is to the guard.
Cheers.
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5115005
They should fit alright with the tyres I suggested, in fact the 225's and 255's should be a big help with all your clearence issues you are worried about. But with wheels of those specs, definitely get your guards rolled. You will need it, especially after lowering. Lowering will also induce natural negative camber.
The tyres I suggested though will give you the most amount of tyre stretch you can legally have with those wheels as well as keep your overall rolling diameter as close as possible to factory.
So lower your car, roll the guards, fir the wheels, pick up chicks. :thumbsup:
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5117390
Hey guys
Thanks all for your replies. Yeah mine is a gtst. Im just worried about getting a defect for my wheels. The mods i've done to my car i try to minimize any defects as much as possible. All my piping in my engine bay is all original parts so when a cop do pull me over it looks stock as a rock so there is no issues =]
Yeah pls advise for my gtst what tyre size will be nice without any dramas? The wheel size might be too big for my car you guys reckon?
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5117788
I run 18x8.5 with 235's on the front and 18x9 with 255's on the back of mine with GTC's. Not sure on the offset since i bought them off a mate, but at a guess they would be + high 20's.
Edited by PM-R33
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5117995
with those sizes if you run your car low you will need to either roll, flare or camber (or a combination of these)
if you keep it 4wd spec then you'll be fine... (but who wants to do that?)
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5118182
I'm running 18x10 + 18 front and rear, rears are 275/35 and front 265/35, this is on a GTS-4 but has had GTR guards put on the back though
Yeah thats wheels are heaps too big for my car. I'll probably gonna go with a smaller size maybe 18x8 front and 18x9 rears.
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5128210
Hi
Thanks for the help
hey mate you can run a 235 on a 10" just a fair bit of stretch which you wont need with your current hieght id go either 245 or 255..
levinboy has a gtr so 265's all roundis no problem becuase his guards are heaps wider from the factory.
front i'd go with above suggestions
the wheel size you wont have any police dramas unless they are hanging outside the guards and your tyres are fairly stretched so i wouldnt worry to much but its always a good idea to have back RWC rims.. stockies ftw
https://www.sau.com.au/forums/topic/310388-volk-gtcs/#findComment-5128396
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
