QWK32 - i have a copy of the software yes..
mods are
HKS GTR-s
front mount
3" exhaust
greddy boost controller
the guy before me had haltech on it but i saw alot of advantages to the nistune so i went that way..
i have acopy of all the base maps aswell, is there some things i can do to that to help things?
i also have a apexi turbo timer which outputs the AFR'S, as soon as you touch the accelerator at 60k's it goes from 14.5 to 10.5 or even 10.0 sometimes..
thanks again
  • Replies 41
mods are
HKS GTR-s
front mount
3" exhaust
thanks again
don't pay any attention to the apexi timer reading. the stock narrowband O2 sensor can't be trusted with any value apart from ~14.7, even then i'd doubt its accuracy. if your getting a reading in the 10's on the pen timer, it could really be a value anywhere from say 10-13.
what tune do you currently have on the ecu, stock maps? on the stock maps it will run rich once on boost even with the GT-RS. i suppose you could take a bit out of the high rpm, high load part of the fuel table, but without getting a wideband O2 sensor to check it you wouldn't know if you've taken too much out. do you have access to a wideband O2 sensor?
also i'd be interested to see if you coming close to the limits of the stock AFM, what boost are you running? link up to the ecu with the software and open the timing map, then watch the map tracer to see how close to the right hand side of the map it goes when you rev it out under load. ideally you don't want it to hit the last row of cells. also check the fuel map, it has a smaller load scale than the timing map so you can run off the edge earlier than you will on the timing map.
flippin' heck
i thought you could get Nisstune's for all Stags. i was looking forward to putting one in my S1 later this year :P
you can, but you have to be willing to chop and rewire your ecu loom to a Z32 ecu plug so you can use a Z32 ecu.
don't know if this would work, just an idea. but could you replace the stagea engine loom with a late model R33 engine loom? engines are the same so electrical plugs should be the same. probably have to splice in a few wires that go to other areas of the car, should be an issue though. then you could easily run a Z32 Nistune ecu without having to hackup, identify, and rewire the stagea loom.
i have stock maps loaded, no tune has been done since the board was fitted... don't have access to wideband.
using stock afm atm but i have a z32 ready to go (wiring is all sorted just needs to be plugged in). next part sounds like too much effort!! lol
i have no idea once it comes to the tuning side of things so yeah, i friend works at a workshop that has just signed up with nistune so i might just get them to tune it for me.
  • 1 year later...
I am trying to find. Who in sydney does nistunes and has had heaps of expirence and has a 4wd dyno
Someone has recommended CRD for tuning. And I do believe they have a 'special' offer in their business thread on these forums.
But I've never done this before so....
Unigroup.
Either get them to drop the front driveshaft or drop it yourself.
If they are happy to let it on the dyno with the little green plug pulled then you can go that way.
I would strongly suggest using them.
Unigroup.
i want unigroup to do it but i am a fusy prick and i want it done in 4wd. Unigroup know envy performance and they have a 4wd dyno and sometimes use it so i am trying to see what i can hook up.
What difference does a 4WD dyno make? Nearly 100% of the time your car peddles around on the rear wheels.
If Yavuz uses the Envy dyno it will be for cars that does allow easy 2WD mode.
Best bet is to give them a call and see what they say.
I paid extra for a 4wd dyno once but then thought why did I do that ? There is no point whatsoever fussy or not. Just drop the front driveshaft and pull the fuse and the 2wd dyno will do just as well. The only difference is you will get a rwd power figure but so what ? The tune and output is the same. You can always look out for a dyno day on a 4wd if you must have the awd figure.
...and it will be within a bees wang of being the same anyway.
not quite true.
my car dyno'd at 210rwkw with the front shaft dropped on a 2WD dyno.
on an AWD dyno it dyno'd at 178awkw - same car - same mods - same boost.
different dyno, yes, but i doubt it would account for a diffence of some 30+kw. lots of mechanical loss of power in the drivetrain. does that mean the car would go harder in 2WD mode? i have no idea.....but the dyno doesnt lie...much. heheh.
(out of interest, that was done on an eManage Ultimate. i now have a Nistune that i'll be throwing in and getting retuned. Mod's won't have changed at all, so it will be verrrrry interesting to see what figures they can pull out of the Nistune vs the Emanage)
Edited by SMOKEYC34
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
