so we all know guys working at supercheap are abunch of fags and dont really know much about cars. i found this out first hand yesterday. so grab a seat.
went to supercheap to get a fuse for my mate. went in and bought what i had to and come to the counter and the covo goes:
guy: nice car man
me: thanks (after i pay i walk out and he comes with to check my car out)
guy: (i have a retun flow cooler so two pipes can be see in passsanger side) wow twin turbo GTT
me: no single turbo
guy: it has two pipes coming out
me: its the intercooler kit using stock setup
guy: ahhhhhh (feeling like a noob now) looks twin turbo
guy: so i heard you come in. sounds good but it drones dont you think?
me: no
guy: you have extractors in this? (at this point i was laughing hard inside that i almost laughed at his face)
me: ummmm no
guy: what do you have?
me: its a custom 3.5" from the turbo back.
guy: you should get extractors man. iv heard alot of GTT and have reccomended them putting on extractors and it tones the noise down a little and sounds mega tough
me: (now thinking this guy is an idiot, i decided to play along) oh really? how does the set up work? does it go from the turbo manifold into the turbo then turbo into the extractors then into the exhaust?
guy: ye or just have extractors
me: what a bout the turbo?
guy: have them custom fit the turbo onto the extractors
me: ummmmm no i like it how it is. (thought id play with him more) oh do you guys have motul oil?
guy: ah the best oil for imports. now its now called royal purple. the motul oil is purple but we dont stock it.
me: what?
guy: ye its the best oil.
me: so whats royal purple called now?
guy: i dunno but its a no name now.
me: ummmm ok...bye
hahahahahahaha idiots.
lol poor kid, should stick to n/a's.
although manifolds are also called headers and extractors, depending on who you talk to. I had fujitsubo extractors on my N/A many many years ago, and they made it drone like a mofo.
sounds like the tards at Autobarn trying to sell me nulon oil and trying to also say it's better quality than the Motul 8100 which is more expensive as well lol.
Or the guy at Sprint who reccommended one coolant over another because it had 'more shit in it'
finally got round to taking some better pics...
HELLAFLUSH!
:P
dezz.
do this.
now.
failing that... this:
actually... fuck everything else. get an M3. make it look like that.
Oh Lordy that is nice!
guy: nice car man
me: no single turbo
me: no
me: ummmm no
me: what?
me: ummmm ok...bye
Ah man!
What you said about the guy is = :P
dezz.
do this.
now.
Car itself looks good, not really digging the red centres though
and after reading the thread the guy posted about m3 vs GTR etc, can't say I'd be too keen on buying one myself...They can look good though
yeah I never picked the V35 as a bolt on flare look car, but I guess it's that close to a 350Z in looks that it can actually pull it off. Love the all black with the metallic coloured centre. awesome.
^^Damn it looks tuff.
I am not a fan of blacked out tail lights, but this is actually pulled off very well.
Yeah the 350Z Veilside Ver. 3 Body kit has bolt on flare guards and looks tuff as!
Veilside Ver. 3 Body kit for the 350Z is probably 1 of the kits I like, cuz as we all know Veilside kits are a bit of a hit or miss.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
