I really want a Supra but I can't really justify spending an extra $5000 just for a manual transmission. I'm only keeping this car for about a year.
It's 3 years newer for $5k more (starting price..) If all else is equal that's not a big difference in price for a 3 year newer car..
why not get the AWD r34 then add in the rb25det later on (i have no idea if this is possible)
Its probably the most complicated engine swap to do as far as Skylines go.
oh no, there's a 1.8L carby R32 that is a headfuck to put an RB26DETT into. that could possibly be a touch harder.
At the end of the day its easier and much much cheaper to sell a car and buy one with the same specs, than to try and upgrade it.
get another hobby, like kidnapping prostitutes
make sure you grab the independant ones. the ones with pimps are a mess to clean up after, and usually you have to dispose of bodies.
fuuuuuuuuuuuuu was changing sparkplugs and one of the coilpack connectors crumbled. Now im down one cylinder and car stuck at friends house :D
How much would a coilpack loom cost from Nissan?
JustJap has them IIRC.
coz guys who buy V35's in oz want them as cheap alternatives to IS300's. they're not very courageous when it comes to mods.
there's a few guys in QLD who have baller V35's tho, but after talkin to them, they cbf with forums.
i was thinking about grabbing one, but now i want to see what happens with this toyo FT86 thing.
Whats the go with jspec's website? did it really get hacked or did everyone just get over it?
You'll be waiting a while before it affects australia in any way.
<rant>Most of the guys who buy IS350's are guys who just got into the 60K plus job market, are working profesional jobs and wanna impress their mates with a fancy car with a label that is somewhat luxurious. They're the same wankers that buy base model Mercs and 3 series Beemers. Likewise most of the guys who buy V35's are usually the same type but are either hard up for cash or are actually smart with how they spend their money (so they get luxury for a lower price, then brag to their IS or 3 series driving colleagues how their cars are better).
Either way, none of them will ever ever ever mod their car with epic low or gangster fitment.</rant>
Yeah some romanian guys managed to use a client login to upload a rootkit that then overwrote every single file on the webserver folders with a worm. Unfortunately this overwrote pretty much all the code I had done, and since I'm not free to do them any more Craig's doing em again from scratch. He was supposed to launch at Christmas, but it hasn't happened. Not even sure why there was no backup of all the stuff I did.
Its like some of the people I work with who want to buy [insert base model of each range of BMW/merc etc]. I rather be walking then seen in a 320, or 118, Paying that money for the brand, when you can pay a little more and get a decent car out of it /rant
WTF no backups of a biz? How many hrs does it take to put together a site like the old one?
Well I'm back...
I didn't buy any of the cars I just posted.
I bought a 1998 Manual Supra. White. Immaculate inside and out. Like new. Comes with some black wheels and chrome lip.
Picking it up in a week.
WIN.
I made backups onto the PC i used for development, but unfortunately I think that PC was formatted or something. It took me the good part of 3 years to get the backend feeding all the data from auctions, japanese car yards etc properly, and the same amount of time for Craig to develop the backend, admin system etc. all of which was lost.
he's done a fairly good job of restoring it and polishing it up, its got all sorts of fancy 2.0 stuff now from the preview I saw.
nothing a hammer and an angle grinder cant fix
edit: also tackled my boats ignition problems, no power coming out of the power solenoid, so replaced that. then had some power running to the starter but the started wont budge. so pretty much had to take off all the carby covers to get the f**ker off.
would be nice to go for a fish on sunday :|
Edited by GTR-boy
Well I'm back...
WIN.
Nice.
Whats happening with the other two cars?
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
