I really want a Supra but I can't really justify spending an extra $5000 just for a manual transmission. I'm only keeping this car for about a year.
It's 3 years newer for $5k more (starting price..) If all else is equal that's not a big difference in price for a 3 year newer car..
why not get the AWD r34 then add in the rb25det later on (i have no idea if this is possible)
Its probably the most complicated engine swap to do as far as Skylines go.
oh no, there's a 1.8L carby R32 that is a headfuck to put an RB26DETT into. that could possibly be a touch harder.
At the end of the day its easier and much much cheaper to sell a car and buy one with the same specs, than to try and upgrade it.
get another hobby, like kidnapping prostitutes
make sure you grab the independant ones. the ones with pimps are a mess to clean up after, and usually you have to dispose of bodies.
fuuuuuuuuuuuuu was changing sparkplugs and one of the coilpack connectors crumbled. Now im down one cylinder and car stuck at friends house :D
How much would a coilpack loom cost from Nissan?
JustJap has them IIRC.
coz guys who buy V35's in oz want them as cheap alternatives to IS300's. they're not very courageous when it comes to mods.
there's a few guys in QLD who have baller V35's tho, but after talkin to them, they cbf with forums.
i was thinking about grabbing one, but now i want to see what happens with this toyo FT86 thing.
Whats the go with jspec's website? did it really get hacked or did everyone just get over it?
You'll be waiting a while before it affects australia in any way.
<rant>Most of the guys who buy IS350's are guys who just got into the 60K plus job market, are working profesional jobs and wanna impress their mates with a fancy car with a label that is somewhat luxurious. They're the same wankers that buy base model Mercs and 3 series Beemers. Likewise most of the guys who buy V35's are usually the same type but are either hard up for cash or are actually smart with how they spend their money (so they get luxury for a lower price, then brag to their IS or 3 series driving colleagues how their cars are better).
Either way, none of them will ever ever ever mod their car with epic low or gangster fitment.</rant>
Yeah some romanian guys managed to use a client login to upload a rootkit that then overwrote every single file on the webserver folders with a worm. Unfortunately this overwrote pretty much all the code I had done, and since I'm not free to do them any more Craig's doing em again from scratch. He was supposed to launch at Christmas, but it hasn't happened. Not even sure why there was no backup of all the stuff I did.
Its like some of the people I work with who want to buy [insert base model of each range of BMW/merc etc]. I rather be walking then seen in a 320, or 118, Paying that money for the brand, when you can pay a little more and get a decent car out of it /rant
WTF no backups of a biz? How many hrs does it take to put together a site like the old one?
Well I'm back...
I didn't buy any of the cars I just posted.
I bought a 1998 Manual Supra. White. Immaculate inside and out. Like new. Comes with some black wheels and chrome lip.
Picking it up in a week.
WIN.
I made backups onto the PC i used for development, but unfortunately I think that PC was formatted or something. It took me the good part of 3 years to get the backend feeding all the data from auctions, japanese car yards etc properly, and the same amount of time for Craig to develop the backend, admin system etc. all of which was lost.
he's done a fairly good job of restoring it and polishing it up, its got all sorts of fancy 2.0 stuff now from the preview I saw.
nothing a hammer and an angle grinder cant fix
edit: also tackled my boats ignition problems, no power coming out of the power solenoid, so replaced that. then had some power running to the starter but the started wont budge. so pretty much had to take off all the carby covers to get the f**ker off.
would be nice to go for a fish on sunday :|
Edited by GTR-boy
Well I'm back...
WIN.
Nice.
Whats happening with the other two cars?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
