I really want a Supra but I can't really justify spending an extra $5000 just for a manual transmission. I'm only keeping this car for about a year.
It's 3 years newer for $5k more (starting price..) If all else is equal that's not a big difference in price for a 3 year newer car..
why not get the AWD r34 then add in the rb25det later on (i have no idea if this is possible)
Its probably the most complicated engine swap to do as far as Skylines go.
oh no, there's a 1.8L carby R32 that is a headfuck to put an RB26DETT into. that could possibly be a touch harder.
At the end of the day its easier and much much cheaper to sell a car and buy one with the same specs, than to try and upgrade it.
get another hobby, like kidnapping prostitutes
make sure you grab the independant ones. the ones with pimps are a mess to clean up after, and usually you have to dispose of bodies.
fuuuuuuuuuuuuu was changing sparkplugs and one of the coilpack connectors crumbled. Now im down one cylinder and car stuck at friends house :D
How much would a coilpack loom cost from Nissan?
JustJap has them IIRC.
coz guys who buy V35's in oz want them as cheap alternatives to IS300's. they're not very courageous when it comes to mods.
there's a few guys in QLD who have baller V35's tho, but after talkin to them, they cbf with forums.
i was thinking about grabbing one, but now i want to see what happens with this toyo FT86 thing.
Whats the go with jspec's website? did it really get hacked or did everyone just get over it?
You'll be waiting a while before it affects australia in any way.
<rant>Most of the guys who buy IS350's are guys who just got into the 60K plus job market, are working profesional jobs and wanna impress their mates with a fancy car with a label that is somewhat luxurious. They're the same wankers that buy base model Mercs and 3 series Beemers. Likewise most of the guys who buy V35's are usually the same type but are either hard up for cash or are actually smart with how they spend their money (so they get luxury for a lower price, then brag to their IS or 3 series driving colleagues how their cars are better).
Either way, none of them will ever ever ever mod their car with epic low or gangster fitment.</rant>
Yeah some romanian guys managed to use a client login to upload a rootkit that then overwrote every single file on the webserver folders with a worm. Unfortunately this overwrote pretty much all the code I had done, and since I'm not free to do them any more Craig's doing em again from scratch. He was supposed to launch at Christmas, but it hasn't happened. Not even sure why there was no backup of all the stuff I did.
Its like some of the people I work with who want to buy [insert base model of each range of BMW/merc etc]. I rather be walking then seen in a 320, or 118, Paying that money for the brand, when you can pay a little more and get a decent car out of it /rant
WTF no backups of a biz? How many hrs does it take to put together a site like the old one?
Well I'm back...
I didn't buy any of the cars I just posted.
I bought a 1998 Manual Supra. White. Immaculate inside and out. Like new. Comes with some black wheels and chrome lip.
Picking it up in a week.
WIN.
I made backups onto the PC i used for development, but unfortunately I think that PC was formatted or something. It took me the good part of 3 years to get the backend feeding all the data from auctions, japanese car yards etc properly, and the same amount of time for Craig to develop the backend, admin system etc. all of which was lost.
he's done a fairly good job of restoring it and polishing it up, its got all sorts of fancy 2.0 stuff now from the preview I saw.
nothing a hammer and an angle grinder cant fix
edit: also tackled my boats ignition problems, no power coming out of the power solenoid, so replaced that. then had some power running to the starter but the started wont budge. so pretty much had to take off all the carby covers to get the f**ker off.
would be nice to go for a fish on sunday :|
Edited by GTR-boy
Well I'm back...
WIN.
Nice.
Whats happening with the other two cars?
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
