About 85%?
I know a GTS-R that's going to be up for sale soon... ;)
Meh 3k posts is nothing.
I think Tharaka racked up double that in half the time!
why would i want some box? :)
and bozodos got a shitload of posts quick by trolling the wasteland.
GTR-BOY if you seriously are looking at n/a r33's for when your getting your Ps let me know, i will be selling mine in a month or 2 ( get off my Ps )
My car just has the usual stuff, making a healthy 123rwkw also (P plate legal) never had a issue with it in the 2 years I've been driving it, oh and its a 95.
cool, ill probably start looking at them around august.
how does the power feel? is it arse out power?
looking for a car i can also thrash at the track.
Actually they are a band off FAT WRECKORDS, which was started / founded by Fat Mike (Michael John Burkett) and his wife, Erin in 1990.
Fat Mike is the lead singer and bass player for the band, NOFX.
On the note of Nitrous Records, RUFIO, one of my fav bands is on that label.
lol, im going to get sucked in to your little game and say NO! they are an awesome band, not k-mart clothing or nitrous :) .
i just finished watching a dvd of there's called nofx backstage passport where they toured some countries that no-one has played a concert at before, it was really good, they went to south africa and indonesia, china and south America and a few others.
Yeah Ash i think i need to go see a dentist and dematologist
Hows your new car??????????????????????????????????????
its ok
taking it to laurance tomorrow to get it lwoered again and looking at some knocking noise im getting from one of the struts. other then that its good. it got called a camry today lol.
Well I turn 21 and will be putting it up on carsales early July and being a N/A probably will sell like a hot cake to a P-plater. (if you look on carsales there is hardly any n/a 33's and the ones that are on there look like shit or have been trashed, took me a while to find a nice one)
The power is good, once you get above 3500-4000rpm you can feel it coming on strong, there is a dyno sheet in the n/a power thread somewhere of my car. Nice and smooth, made a extra 20ish kw atw then a mates 4l ford that had some work done on it haha.
Regarding track, I have taken it on Winton, went very well around corners but could not compete with STI's GTSTs down the straights for obvious reasons but was still a shit load of fun :D
Oh and there is another 33 N/a that has the exact same power (123rwkw) and he did a 14.5 down the quarter mile.
But yeh when I'm ready to put it up on carsales / forums I will chuck you a PM if you like
Cheers
Regarding track, I have taken it on Winton, went very well around corners but could not compete with STI's GTSTs down the straights for obvious reasons but was still a shit load of fun :)
Cheers
cool. ill probably be looking for a black, grey or dark blue s2.. but if i find a neat white one then why not :D
is that the car itself making some smoke in your avatar?
yeh thats me at DECA in my avatar, back when i had a carbon bonnet on :D
I was looking at black S2s but couldnt be too fussy because most of them were shit to be honest.. one was in northern suburbs i looked at..s2 gts4 had key marks all over it was terrible.. was just a piece of crap in general. Trust me you will be like wtf hard to find a clean n/a 33.
I was going to ask when you were going to sort that out :D
Monday week away I start getting a whooooolllle lot more money than usual so probably then :) Can't wait to splurg on myself again, and my car! :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
