probably a mock up :(
i've only ever seen 1 on the road. bout 5 years ago lol
sti > evo :ninja:
pffft your opinion fails :)
lol. in other news i got my new bushes for the gtr, also my new metal cat arrived from boost bitz, it looks really good and at a good price also aussie made, now all i need is the front pipe to finish it off.
we spoke about this..... straight pipe remember?
Pffftttt evo shits on sti!!!
bad :D
pffft your opinion fails :D
bad :(
im caveing in to peer pressure lol. the problem is my exhaust tip doesnt stick out from the back so all it will do is make a mess on the back and burn that lovely paint.
black/carbon exhaust shield will help a bit :(
briefly owned a Evo 6 Tommy Makkinen and it was a blast to drive. drove one of the evo 7 we imported for a mate and it was disappointing compared, even with the extra yaw control... drove a evo 8 rs and it was balls out fun, but i'd never use it off a track cos its just a rally car shell.
after evo 6 the only good evo is a stripped out race evo. 7 upwards just try to do too much.
yup, stick a nice resin coated piece of cloth next to a pipe that's hot and occasionally shoots flames.
you're a fuckin genius.
aluminium sheeting to protect bumper and rivets to hold it on. kgo.
once the resin is dried its going be the same effect as having the bar there
if its going to catch fire its going to catch fire (bar or the exhaust shield)
considering the showie nature of his car doubt he going to pop rivet into his rear bar
yeah i wouldnt pop rivet ill probably cable tie it on lol.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
