Was told splitfires are the best, wouldn't know cos I never had coilpacks fail on me.
I now have a dilemma once again, this time whether to sell my R for built one or not...
you have a stock skyline. find out how many shit coilpacks you've got using that process of elimination described before, then buy some secondhand ones and swap em in (only the ones that are dead). you can look at aftermarket coilpacks when you start pushing serious power.
if you buy a full set of 6 or 3, you'll end up with a couple of spare you can swap in later when the other die. will cost you about $60. That's how much it cost to fix the missing spark on my ceffy... 3 fubar coils.
how much would you sell for?
give me a factory spec gtr over a built one anyday
$23k, have modifications such as hks gt-ss, power fc, cusco coilovers, 18x10 advan model t5 rims, hks front pipe, hks catback zorst, os giken triple plate clutch, 302rwkw, 100k service done
Good luck in finding one.
there's 3 1997 and 1998 MP1 R33 GTR's comin up at auction this week. All with xenons, one with heavy mods, one that looks buttfuck ugly and another that's bog stock.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
