Yeah, I haven't heard anything about the boom lol. Hear it mainly from trade school? They would do that deliberately to keep everyone interested. Imagine if they say the industry is going into recession, imagine how many people will stick through? Plus they don't get their handouts from the govt. lol
Apps must have a big job on then :laugh: Understandibly hire a few, but 12? Good luck anyway man, I'll ask around see if I can help you out, but I'm not holding my breath unfortunately. Given CJ Pearce a call?
Has anyone here ever had to replace their tie rod ends?
According to mechanic mine are on teh way outskies.
Yeah. I'm sure heaps of people have, mine cost about $80 or so i think
Also, i sorta want a new car, but I know that mine would be too much of a pain in the ass to sell. I don't wanna spend waste more money on it, but maybe thats what itd take for me to love it again. What to do >_<
Nope, what kind of work do they do? think I've asked you that before...
enterprise database that stores records
a lot of information on networks etc are just records in a database
like each of these posts on the forums, is a simple row in a database
one of my mates in england is currently working on converting his Motec ECU to fibreoptic, so all it has is one cable coming out of it carrying up to 256 different signals.
realistically he says he'll have 3 cables, one to the dash, one to the engine bay and another to boot/fuel delivery system. still... 3 optical cables < 11ty billion wire cables that can short out, get interference, start fires etc.
Once he's finished prototyping it, I'm so gonna get on that.
ya heard 32s have 40 + kgs of wiring in it...and to run the car, you prob only need 5kg of wiring in it... lol...
Haha, and I have wiring for stereo system still in place... Dynamat in boot and probably hidden in rear seats.
Going to get rid of them all.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
