All I have is a front road!
But I move in 2 more days and I'll at least have a garage floor then! :thumbsup:
I did my fj20t transplant in my dato1600 on the road (and a few other cars which I'm not particularly proud of owning)
  • Replies 125
Had a ride in Noels forklift mobile on the weekend, very nice! it brings on the power in such a linear fasion. I kinda wish i built one for my gtr now....but then again thats straying from my plan!
That's why plans can be changed >_<
Have a ride in mine when you're down next time. Check NSW for dyno sheets
That's why plans can be changed :)
nah last time i wnet away from my plan i pretty much ending up hating a car i once loved, I dont want to do that again by going too far
Mansoors old blue gtst?
I understand where you're coming from
Still come for a ride when you're down next :cool:
thats the one i spent like 40k and ended up with a bucket of shit that i hated
this time im enhancing rather than re-engineering!
ok i will come for a drive some time
Yeah that one and the elusive dissapearing oil...
He just got the other blue one going!
You won't regret building a 30, I'm sure all us 30 owners can attest to that :worship:
i am yet to hear of someone with a working 30 that they haven't liked.
no doubt, but after last time i dont think my nerves can handle it!
  • 3 weeks later...
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
