I am finally close to removing my Greddy TD06 manifold and Type R wastegate and install my 6Boost manifold to be used with the same TD06 turbo.
I hit a small problem as i have a new Greddy Type R gate to use with the 6boost manifold, but with a rough trial fit the big Greddy gate wont go close enough to the collector for the 6boost manifold to be able to provide good boost control
So left looking for a replacement wastegate. Looking around the 45mm mark and the Tial V44 or the Turbosmart Hypergate 45 look to be the best options. The Turbosmart gate is a tad shorter by 10mm but both appear to be far smaller then the Greddy gate and will be able to be packaged well.
Has anyone got experience with either of these gates being used on 6boost manifolds? Which is the best option and where is the best place to source?
https://www.sau.com.au/forums/topic/311467-tial-vs-turbosmart/
I use a Tial 44mm ext gate with my 6boost manifold, never had any problems. When I was looking around on what to purchase I did some research on these forums first. They both are pretty much identical in terms of reliability and performance according to alot of people. I ended up going for the Tial however cause my mate couldn't get in the Turbosmart through his work at the time.
Just don't skimp out and buy yourself a chinese copy because the quality is probably not as good and you might run into problems down the track with things like the diaphragm malfunctioning and the gate being stuck open. There's alot of nasty stories floating around with cheap ext gates. Purchase from a good, reputable brand and you shouldn't have any dramas.
Edited by GT32
Roy, I have not used a Turbosmart gate but I used to sell both and from past experience the Turbosmart gates are physically larger than most brands on average.
I would try to get your hands of both gates and trial fit the best you can.
Things may be different now so this point could be null and void.
Timing Roy , I know someone that just took a TiAL 44 of a 6Boost manifold on an RB26 and wants to sell it .
He went to a larger Turbosmart because the 44 wasn't big enough when the exhaust was increased to 4 and 3.5" .
Stay tuned , will be with the owner in a hour or so .
Cheers Adrian .
Cheers Adrian .
That could be a goer as its readily available. Some pics and a price would be handy
Doesn't Kyle only recommend the turbosmart 50mm gate?
He did when he made mine up.
He said he only stocks the Turbosmart gear these days, but said to go for either the 45mm Turbsomart or the 44mm Tial...he didnt seem fussed.
Shits me how you buy the Tial gate, then there is an extra $100 in getting the V-band flanges. FFS you think they would supply the thing with the flanges and clamps !
uh... all tial gates i've bought have come with one flange for the bottom and one flange for the side aswell as vband clamps for both of those...
Huh...they do supply the flanges and clamps with the gate.
Well they ones I bought were all supplied with the gate.
http://www.atpturbo.com/mm5/merchant.mvc?S...tegory_Code=WGT
Edited by juggernaut1
You may want to go larger, unless it's less of an issue on the 2litre.
In regards to wastegate placement and boost control. If I have ever supplied you or a friend with a turbo kit with a tial 44 for any kind of RB, when the order was placed the conversation would have been had that it is not good enough for the job, I do not recommend you use it, be aware X/Y/Y may happen, and if you must run it, and have boost control problems, do these things to fix it.
Original here:
http://www.supraforums.com.au/forum/showth...632&page=10
Edited by DCIEVE
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
