Hello :blink:
Im trying to figure out a styline route for my R34 4 door. Does anybody know (for certain) what the compatability is between the 2 door and 4 door chassis?
Are the wings/bonnet/front and rear bumper the same on both cars?
https://www.sau.com.au/forums/topic/311473-r34-4-door-vs-2-door-compatibility/
front bar is the same, bonnet same
rear bar is not
wings? you mean front fenders? or side skirts?
- Front fenders the same - Pretty much everything up to the A pillar.
- Whole dash assembly the same.
- Front seats the same
- Front suspension, Rear suspension - the same (...but I've read somewhere - please don't quote me on this - stock front suspension on the sedan is slightly stiffer due to the extra weight when braking)
- Tail lights - different
- Boot - Different
- Rear bar - Different.
Eastbear have some nice coupe/GTR style bumpers and panels for the R34 4 door -> http://www.east-bear.co.jp/
  • Like 1
  • 1 month later...
To have the front bar bonnet off a gtr i beileve you have to replace the bonnet bar an fenders all in one hit.
Also the mounting points for the lights are different as far as I know, which mat suggest the fron uprights needs changing to do it all properly. Otherwise you can knock up brackets to fit the GT-R lights.
i think you will find the front seats are different from 4 door to 2 door.
i purchased a set of front seat rails for a 34 gtt autotechnia brand i think they were, sign said 34 4 door compatible, tried fitting and works out they are only for 2 door version. rang mob who made them and they said the 4 and 2 door are different, and they don't make 4 door version. bolt holes at rear of seat are the difference.
I have a 2001 turbo sedan with the update bumper and wanna take it off to fit a non turbo early model bumper :(
Is there a difference between early model turbo and non turbo front bumpers?
Or are people refering to the non turbo as the standard type then the turbo as the nismo option type?
Attached picture's for reference, the black one to me is the standard bumper with the lip, the orange one the Nismo option bar, then you get the later model round type?
Oh and seats 2 door and 4 door are the same, but 2wd - 4wd are different.
Edited by msports180
Seats are the same. Could be the rails that are different lengths - as you will need to move the seats more for coupes for rear passenger access.
And there's no difference between early model and late model front bumper fitment?
If you are running the stock side mounted intercooler - I do NOT recommend putting a non-turbo bumper - reason being is that it needs the side vent.
If you have a front mount intercooler - the non-turbo bumper will be ok, but may require some modification.
If you intend on keeping the side mount intercooler - your options are limited to the GTT bumper or nismo bumper - or if you're really keen a GT-R bumper, which means you will need a new bonnet, side fenders etc.
Non turbo doesn't have the vent on the side for the intercooler etc. Seeing as I don't want that, that's the reason for going non turbo.
Does anyone know if the tailshafts are the same between 2 door manual gtt and 4 door auto gtt? I need the rear section changed on my 2 door as the center bearing has collapsed on the rear sectin of the two piece tailshaft and I have access to replace it with a 4 door auto shaft and bearing.
Here is a picture of the part in question...
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
