  • Replies 40
I'm swaying to Bridies... think from 2.00pm onwards?
Have left a message with some guy there about reserving a table. I'd like to get a better idea of numbers though... Will add a poll.
What do people think? Good place/time/plan?
you are all a bunch of fkn skanks.....SHAME ON YOU GUYS FOR NOT TURNING UP!!!
Sorry!
I got into a spot of bother Sat night... I've got the battle wounds to prove it. :D
And i've no-longer got a mobile too either as i lost it :Oops:
otherwise i would have called people cause i dont rmember anyones number!
Well. Well. Well.
Team SAU VIC - Me, Snowman, Horus and Funky.
Where was everyone? Sure - we drank enough to make up for it... but jeeze guys.
It's not like this was a surprise event. No-one even called :devil:
We were there from 2.00pm to 11.00pm - so no-one can say 'you must have left'.
Shame.
I know its not a great excuse but I couldnt walk or drive on sunday due to alcohol consumption the night before [brother-in-law's 30th b'day]...
I did say I had b'day's on last weekend and thus didnt guarantee my presence well before the event...but I would have, should I have needed another drink that is :)
if thats too confusing then try this :) :)
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
