Heya all
I've done some laps at wannaroo short track on shitty old street tyres and got a pretty good time while slidding all over the place:) 60 secs flat
Would like to put some half decent tyres on my spare rims 17x8 and 9inch. Currently running 18x8 on my street rims but i've heard 17's are better for racing.
The car was set up for drifting but im kinda liking the track work. Its an r32 with a rb25 neo, 280rwhp, all suspension and handeling has been sorted just need to sort out some tyres.
There are so many different tyres out there and diff reviews but if someone that has tried diff tyres on this sorta car and horsepower pls send me in the right direction
Cheers
Dan
  • Replies 51
from what i have witnessed i reckon the best r-spec radial sprint tyre is the advan a050's atm. i've seen a few people run pb's recently on them
We ran them on the Evo 4 at Lake Mountain over the weekend.
An amazing tyre over the 9km stage and certainly a good option now that RE55s are stupidly expensive.
I personally think A050's are the quickest tyre out there at the moment, closely followed by the O3G's. Imo, the O3G's last a little better though. Need to keep in mind that compound/wear wise, a "soft" AO50 is really fairly equivalent the a "medium" O3G.
re55/dz03g/a050 would be my pick.
I won't run a050 for racing since it only comes in soft and medium but it would be ok for sprints.
out of re55 and dz03 I take the dz03 because they are better if it rains. about the same in the dry
I'm currently on a set of KU36, they're pretty good, for what they are. I've found them about 2 seconds slower on a minute lap track. One quarter of the price though.
Really thats not too bad:) when they get too hot do they loose some grip or are they pretty consistent? Is there a tyre pressure you could recommend for my car, r32 with a bit extra weight in the front cause apperently the rb25neo is a bit heavier?
Federal 595 RSR's seem pretty good too, similar to the KU36 but a bit softer. Road legal for the non trailer queen mob.
and about 1.5 times the price. You can get R888s for that, not that they're much better.
I just bought a set of 215 & 240 x17" medium compound Kumho slicks for the price of RSRs. Admittedly the Kumhos were on special, but so are the Feds...
Nah, I got quoted $176 each for Federal 595 RSR in 255/40 17.
where did you get the slicks from?
sounds like a damn good deal
that's extremely cheap compared to their normal prices. Its damn near the normal 595SS price. I'd go out and buy a set tomorrow at that price! was it from option1?
zebra, any Kumho motorsport distributor can hook you up. http://fsport.com.au/special_offers.html
Yeh Option 1 Harry, I may get a set. My RE55's are buggered and the tyres I've been trying to import have been held up due to a payment transfer messup.
I'd aim for 42 hot mate. So start at around 38 cold and bleed them back straight after your first run. Others may have some input on this, I am by no means the expert re this particualr tyre, and have only experimented a little.
I got my best times on the KU36 starting at 36psi cold. Didn't make note of the hot pressures. But the heavyweight Supra probably put a couple of extra pound in them through heat than your lighter R32.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
