Just purchased an adjustable exhaust cam-gear for my RB25 from Access Autoworks.
It looked like it used an alloy adjustable centre with steel outer gear but when I received it (a family member picked it up for me) I realised the outer gear is also alloy. I have heard some stories about alloy gears wearing & allowing the belt to slip but am wondering if this is a common thing or something that happened once & got spread all over the net? If anyone has had this happen (firsthand or to a mate, etc) how long did the alloy gear last?
Access Auto give a 12-month guarantee so I assume it will last at least a year...
It looked like the inner adjustable part of the new gear would fit in the original steel gear so I have gone ahead today & removed the timing belt & cam-gear, however it missed out on fitting by .7 of a mm (Damn close!) so some machining is needed.
I can take the original gear to work & machine it on the lathe to fit the adjustable centre but wont be able to do that until at least Monday (if I'm lucky) & need car running by Tuesday night as its booked in for tuning Wednesday.
Thinking of running the alloy gear for now, modifying the original ready & periodically (during service, etc) checking the alloy gear for wear.
Then if I need to replace it or if I can just be arsed one day will swap everything back over. It is a bit of a bugger of a job to do twice but!
Basically just after opinions of people who have used them how bad the alloy gears really are...
The anodising is stronger than steel, that's why alloy motorbike rear sprockets last so long. Once the ano wears off they will quickly chew out but i'm guessing that wont happen while you own the car. They could be damaged easier than steel if the belt isnt in good nick.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
