hey guys
im wrecking my r34 sedan im selling everything below is a list of available parts and pm or TXT me if theres anything else you need, i will see if i can get it!
front bar - $400
rear bar - $400
side guards - $150 each
rb25 de engine (95 000 KMS) - $1800
triptronic gearbox - make an offer
spoiler - $100
bonnet - $300
rear tail lights - $350 for set
4 X 19" low profile falken tyres(about 70% tread) - $170 each
front halfcut without engine (i.e railings for any smash reapairs) $ 450
if your interested in buying the full car, inc engine, all panels halfcut to repair front end then im selling it as a whole for $5000
im located in sydney, NSW 2768 message me on 0425211199 and ill get back to you asap
ill try and have pics up soon
thanks
GUYS ITS NOT LETTING ME REPLY TO PM'S BECAUSE IM NEW ON THIS SITE email me on [email protected]
Edited by SHIVNEIL91
https://www.sau.com.au/forums/topic/312999-wrecking-r34-skyline-4-door/
Do you have the interior moulded carpet?
yeah bud i have the carpet, gimme an offer and we can workout a price. just so you know you will get the quickest reply by texting me
thanks
hay mate can u put up a pic of the centre console for me i need the climate control panel but i think it is different in the 4 doors also i need an ashtray if u have one
cheers
julz
cheers
julz
Sold to me :ermm:
You wouldn't happen to have a 3" exhaust sitting under it you want to sell would you?
umm im pretty sure its a stock exhaust but yeah im willing to sell that. ill just double check for size tomorow pretty certain its not aftermarket but
hey guys
front bar - $400
rear bar - $400
rb25 de engine (95 000 KMS) - $2000 with triptronic gearbox
spoiler - $100
bonnet - $300
thanks
Driver's side A-pillar trim to SA 5159, and centre console armrest plastic hinge please.
Along with a handful of boot interior trim plugs, the ones that you screw out ~4mm then pull out the rest of the way.
yeahp ill get a courier quote. about that hinge im only selling the armrest as a whole unfortunately. i will reply tomorow with a quote
thanks
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
