ok ive got the car running after i installed a highflow turbo, JJR split dump/front pipe modified into a screamer, and wrapped the top half of the dump pipe with exhaust wrap.
started it up and its quite loud, exhaust is flowing out of the wastegate at idle, is this only while its cold? or is this the ghey thing about internally gated screamers?
what could be causing the black smoke as i rev the engine? would it be the standard ECU riching it up coz of the highflow? or anything to do with the dump?
also after running for about 2 mins i noticed the turbo/dump pipe area started to smoke, is this just becuase the exhaust wrap is new?
cheers
jimmy
Unless the wastegate area is perfectly sealed from the exhaust I imagine you will get exhaust flow from 'screamer' all the time.
Black smoke I would put down to standard ECU running overly rich as you mention.
& yes exhaust wrap will smoke for a long time. Takes ages to burn off & generally stinks too!
idle rich is mainly on O2 sensor. Plug it in to a Diagnostic computer and see if that shows lean rich lean rich lean rich .... it doesn't then O2 sensor needs to be replaced.
What is this internally gated screamer? did you chop a section off it for the external gate sound? One of my friend tried it. Car just sounds like a permanent exhaust leak. Didn’t work as expected.
Also you must adjust the stock actuator flange to ensure waste gate is shut. We adjust it free of charge if that was sent in with the turbo. Information regarding "how to" is on my 30 pages thread.
the actuator was bolted onto the turbo when i sent it in, ill have a read 2mro.
taken it for a drive and the bloody thing is overheating, got to 3/4 on the gauge then i came home and turned it off. the 1st drive i accidently left the coolant bleeding screw loose so i thought that was the prob, got home tightened it up let it cool off, went for another drive and the temp went to 3/4 again came home and theres fark all coolant in the system. maybe a leak from one of the water lines to the turbo? i had to reuse the old copper washers coz i couldnt source any, any ideas???????
In This case the actuator has been adjusted. No need to touch that.
If water is leaking through the cooper washers you will be able to visually see it. Get a pressure tester onto the radiator and see where the water is leaking from.
hav a feelin its coz i didnt bleed it properly so ill try that wen i get home.
also the car runs like crap, no power at all under 3000rpm then quickly makes boost to around 15psi and feels sluggish. this is probably coz of the standard ecu yeah?
Well few reasons. First of all turbo is bigger and heavier built with steel so you will notice some sort of lag. Should be getting full boost around 3500 mark. Drive it for 150KMs you will note the response of the turbo improves.
After a good tune with supporting mods, you will get around 250rwkws mark.
15psi on standard ECU = not good. Rich and retard for sure...why are you boosting it without getting it tuned? My only driving after bolting on a high flow turbo would be to my tuner unless you have the wastegate set to standard boost.
ok time for an update, the cooling issue looks to be gone, i bled the system properly this time.
car is running ALOT better now with the boost controller disconnected and it doesnt feel laggy anymore (ecu must of taken out timing and maybe hitting r&r)
but now ive ran into another problem.....overboosting. so i put my foot down boost starts to build around 3000rpm, boost builds quickly to 9psi then about a second later it climbs quickly to 17ish psi then i back off. im guessing this is the split dump :blink: i dont get it but! if the JJR split dump are THAT bad how does he sell so bloody many of them, and i did die grind the inside of the wastegate section on the dump pipe where its fouling.
what checks can i make from here? blowing compressed air into the wastegate??
EDIT: and also SOMETIMES the car stalls after i bip the throttle like its running an atmo bov, i have put the standard one back on but since ive got a different intake pipe its custom return piping, would a slight restriction in the bov return hosing cause it to do this?
Edited by jimmys-33T
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
    • It always seems the uglier an animal is the more is costs
