Many of you would have heard of Robert Marjan's "Dreamcrusher" R32 GTR with the numberplates JUN, well the car just ran a 9.22 @ 155 mph!!! Making it one of the fastest true street GTRs in the world.
Previous visits to the track for testing didn't see any numbers as the guys wanted to make sure the one run they would get would be worth it and spot on as the car has no cage and is a true street car with air conditioning and full interior. The car weighs 1690kg, making the time even more impressive!!!
The car was featured in Motive DVD #3 and I will post the feature up online tomorrow.
The car was built at tuned by CRD using Nitto Performance Engineering engine parts, a HKS turbo, OS-Giken sequential box and custom CRD suspesnion.
And for those who want to know, the car is driven on the street and thats what it was built for!
Congrats to Rob, JIm and all the boys at CRD!
https://www.sau.com.au/forums/topic/313404-jun-runs-a-922-second-pass/
nope, it has extra sound deadening and a stereo system and all the brakes, turbo kit etc adds weight. No weight reduction at all.
Its an Aussie spec GTR on radial tires with full exhaust. Its how its driven on the street!!!
No cage, no chute...nothin.
unfortunately I didnt get proper footage as I was in Melbourne....i went every other time but the time I dont they do it!!! Im tracking some footage down to put up, even if its crappy phone footage, better than nothing
Their is no doubting that it is a nice car but street racing in canberra and street racing in south western sydney, it will only take 1 cop with half a clue and this car will not only be banned from WSID but banned from NSW Roads too.
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
