Many of you would have heard of Robert Marjan's "Dreamcrusher" R32 GTR with the numberplates JUN, well the car just ran a 9.22 @ 155 mph!!! Making it one of the fastest true street GTRs in the world.
Previous visits to the track for testing didn't see any numbers as the guys wanted to make sure the one run they would get would be worth it and spot on as the car has no cage and is a true street car with air conditioning and full interior. The car weighs 1690kg, making the time even more impressive!!!
The car was featured in Motive DVD #3 and I will post the feature up online tomorrow.
The car was built at tuned by CRD using Nitto Performance Engineering engine parts, a HKS turbo, OS-Giken sequential box and custom CRD suspesnion.
And for those who want to know, the car is driven on the street and thats what it was built for!
Congrats to Rob, JIm and all the boys at CRD!
https://www.sau.com.au/forums/topic/313404-jun-runs-a-922-second-pass/
nope, it has extra sound deadening and a stereo system and all the brakes, turbo kit etc adds weight. No weight reduction at all.
Its an Aussie spec GTR on radial tires with full exhaust. Its how its driven on the street!!!
No cage, no chute...nothin.
unfortunately I didnt get proper footage as I was in Melbourne....i went every other time but the time I dont they do it!!! Im tracking some footage down to put up, even if its crappy phone footage, better than nothing
Their is no doubting that it is a nice car but street racing in canberra and street racing in south western sydney, it will only take 1 cop with half a clue and this car will not only be banned from WSID but banned from NSW Roads too.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
