Searching around but has been unsuccessful. In fact ive searched via google etc also elsewhere but no luck.
Any threads someone could point out for a guide to changing coilpacks?
Thought id give this a go, its annoying having to pay through the nose for what so many have suggested is a fairly simple job. Unfortunately my knowledge is limited.... clearly.
Any help or point in the right direction would be appreciated.
Cheers,
Matt
https://www.sau.com.au/forums/topic/313534-guide-to-install-coilpacks/
http://www.skylinesaustralia.com/forums/RB...ark-t42819.html
do the above. when u take the coils out u will see that there all attached to 2 metal brackets. take them off the brackets and replace with new ones. easy.
and never again give ur car to a mechanic to change spark plugs or oil its easy and there are tutorials all over that will help and if u get stuck many ppl on sau will be willing to help so just ask
give ur self 2-3hr max because this is ur first time
totally agree with this. these forums are amazing, i changed my oil for the first time 2 days ago, no problems, following these instructions:
http://www.skylinesaustralia.com/forums/Sk...ngi-t10035.html
only a tiny bit different for the r34, couple of screws, and all was fine :P
these are good instructions for coil packs
http://www.skylinesaustralia.com/forums/Di...tml&hl=coil
step 5 is the most important.
for spark plugs, follow the one above, then just unscrew the plugs below the coil packs
http://www.skylinesaustralia.com/forums/R3...ug-t122284.html
important notes for the plugs: you'll need to have the right size socket for the plugs, its different to a camry (learned that the hard way) and be careful with screws if the engine is hot, its easy to mess them up.
and know what to use:
http://www.skylinesaustralia.com/forums/Sp...gs-t104405.html
its always worth having a look through the reference guides in the forum stickys, and the facts/DIY forum
http://www.skylinesaustralia.com/forums/Fo...ick-t66556.html
http://www.skylinesaustralia.com/forums/Tu...IY-FAQ-f57.html
have fun, let us know how it goes
dunno if its mentioned in those but to remove the coil pack loom from the coilpacks i usually put a flat head screwdriver in the gap at the top, push the tab and twist the screwdriver to lever them apart gently. last thing you want to do is break an expensive coil pack loom from pulling too hard on the plugs
Thanks for all the input lads. Successful effort today took me an hour or so. Spot on there nismoid. Bloody good feeling sorting this out myself. completely sorted out the stutter... Rocker gaskets and brake pads next haha :O) got some searching the forum to do tonight.
I've had a z32 ecu and nistune installed, I'm interested in acquiring the software if possible, hoping to learn a bit about the tuning process. I'm not 100% happy and believe a better result could be had ironing out the tune in normal driving conditions. Early days but it would interesting to have someone drive around and atleast be able to view what's happening with the maps in a live state??
Anyhow, thanks again for the replys gents
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
