Trozzle Posted March 25, 2010 Share Posted March 25, 2010 When riding the clutch, particularly up my driveway, it will frequently begin to make a horrid grinding/drilling sound. I've noticed that if I push the clutch in, then attempt to go again, it just starts making the sound immediately once more. The only thing that will stop it from happening when I try to move again is if I let the clutch out for a few seconds in neutral. It also will occasionally (depending how long I allow it to make the sound) give off a strong burning metal smell....similar to an actually clutch smell, but distinctly not. Also, recently there will be a very faint chirping/circulating squeak sound coming from the clutch area when idling in neutral, which disappears with even the *SLIGHTEST* touch of the clutch pedal... Could this indicate a problem with my thrust bearing? The clutch is only about a year old, and has only done just under 20,000kms. I have only ridden it twice at about 3,000rpm for a second or two by accident, trying to get out of stupid traffic...though this smell is different to the above one. Otherwise, I am very easy going on the clutch itself, particularly changing gears. I wouldn't expect it to be damaged from use or worn out, which is why I don't think it's the cause. The clutch is an Exceedy (I think heavy duty) organic Thoughts? Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/ Share on other sites More sharing options...
BezerkR32 Posted March 25, 2010 Share Posted March 25, 2010 yeh my money would be on the release bearing. When riding the clutch, particularly up my driveway, it will frequently begin to make a horrid grinding/drilling sound. I've noticed that if I push the clutch in, then attempt to go again, it just starts making the sound immediately once more. The only thing that will stop it from happening when I try to move again is if I let the clutch out for a few seconds in neutral. It also will occasionally (depending how long I allow it to make the sound) give off a strong burning metal smell....similar to an actually clutch smell, but distinctly not.Also, recently there will be a very faint chirping/circulating squeak sound coming from the clutch area when idling in neutral, which disappears with even the *SLIGHTEST* touch of the clutch pedal... Could this indicate a problem with my thrust bearing? The clutch is only about a year old, and has only done just under 20,000kms. I have only ridden it twice at about 3,000rpm for a second or two by accident, trying to get out of stupid traffic...though this smell is different to the above one. Otherwise, I am very easy going on the clutch itself, particularly changing gears. I wouldn't expect it to be damaged from use or worn out, which is why I don't think it's the cause. The clutch is an Exceedy (I think heavy duty) organic Thoughts? Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5150352 Share on other sites More sharing options...
Trozzle Posted March 25, 2010 Author Share Posted March 25, 2010 Coolies, any rough ideas on price for a replacement? And/or recommendations for brand or anything? or just go straight genuine? Thanks Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5150692 Share on other sites More sharing options...
Luciano Posted March 29, 2010 Share Posted March 29, 2010 the thrust bearing itself will cost stuff all, the labour can obviously get a little pricey as your gearbox needs to come out Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5156117 Share on other sites More sharing options...
BezerkR32 Posted March 29, 2010 Share Posted March 29, 2010 $800 will get you a full clutch kit replacement. 4 hrs labour is about the usual + bearing $40 if the clutch is ok. so say about half. the thrust bearing itself will cost stuff all, the labour can obviously get a little pricey as your gearbox needs to come out Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5156193 Share on other sites More sharing options...
Trozzle Posted April 1, 2010 Author Share Posted April 1, 2010 I don't anticipate there being an issue with the clutch, unless it is faulty. Otherwise it has received very little abuse whatsoever, and symptoms/troubleshooting is suggesting otherwise. At least that's some food for thought tho, thankyou. If the clutch is bung, I don't know whether I'll just leave it be for now, and get a good double plate and possibly new flywheel further down the track, or rip it out and sell it to my mate for sweet shit all...ehh we'll see, but if it's just the bearing then that's not much at all. Thanks for the input Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5161125 Share on other sites More sharing options...
jrm Posted April 1, 2010 Share Posted April 1, 2010 Pretty sure from what I've read the symptoms you're describing with the noise (with pressing clutch pedal) indicate more an input shaft bearing noise? IE: Foot off the clutch = noisy/rattling foot on the clutch = noise instantly goes away Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5161278 Share on other sites More sharing options...
Humbla Posted April 1, 2010 Share Posted April 1, 2010 I had a yucky noise in the clutch,got the spiggot buch or whatever it is an the thrust bearing replaced,no more noise fixed. Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5161696 Share on other sites More sharing options...
Trozzle Posted April 1, 2010 Author Share Posted April 1, 2010 Input shaft bearing in gearbox is fked too Jrm, but I know that noise. It's the horrid grinding/drilling noise when I ride the clutch a little bit (1000-1500rpm) up my driveway that is the main symptom. When I let my foot off at idle in neutral, it makes the sandy sound of the input bearing, but there's a slight chirping sound somewhere else. This goes away the instant I touch the clutch pedal and apply the TINIEST bit of pressure (not even depressing it at all, just enough to "load" or touch the thrust bearing) Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5161792 Share on other sites More sharing options...
Trozzle Posted April 6, 2010 Author Share Posted April 6, 2010 Having box dropped today for inspection, fingers crossed on thrust bearing Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5166640 Share on other sites More sharing options...
GDZ-14R Posted April 7, 2010 Share Posted April 7, 2010 I had the exact same issue with my old crappy NPC button clutch - it did not want to be riden at all.. Changed the entire clutch, pressure plate, release and spigot. The clutch was worn badly from improper fitment, but not sure if it was that or the spigot that caused it. Either way do your self a massive favour and ensure that the idiot who fits it cleans the entire assemebly and bell housing of all grease, and use graphite powder for assembly instead. Demand it!! Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5169618 Share on other sites More sharing options...
94 skyline Posted April 8, 2010 Share Posted April 8, 2010 Input shaft bearing in gearbox is fked too Jrm, but I know that noise. It's the horrid grinding/drilling noise when I ride the clutch a little bit (1000-1500rpm) up my driveway that is the main symptom.When I let my foot off at idle in neutral, it makes the sandy sound of the input bearing, but there's a slight chirping sound somewhere else. This goes away the instant I touch the clutch pedal and apply the TINIEST bit of pressure (not even depressing it at all, just enough to "load" or touch the thrust bearing) Where did you take your car to get the gearbox checked and how much, having troubles with my box, Cheers Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5170490 Share on other sites More sharing options...
spec-V Posted April 24, 2010 Share Posted April 24, 2010 Hey Troy, I'm sorry to hear about your clutch issues, as you know I replaced the clutch for you before I sent it down when you bought it (can't beleive its been over a year!) The clutch in it is a Exceedy Sports Organic with a upgraded pressure plate from a R32 GTR HD kit. All parts were installed brand new and correctly by my one and only trusted mechanic. It sounds from whats written here, your slave or throwout bearing could be the culprit, as for the heavy grinding at low revs, thats sounds more than likely a gearbox gear issue, ie your Input shaft, syncros ? What was the result of dropping the box? Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5197633 Share on other sites More sharing options...
USS Posted May 14, 2010 Share Posted May 14, 2010 Having box dropped today for inspection, fingers crossed on thrust bearing Did you find out what was wrong with your car? My car has similar problems and its an r34 gtt. Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5232854 Share on other sites More sharing options...
Trozzle Posted May 14, 2010 Author Share Posted May 14, 2010 Didn't drop the box, and yeah Zac I'm not sure if I've worded things right, but it's definitely not the gearbox. Technically the internals of the box are more or less stationary when it happens. Good thing is I don't think it's happened since I said I was going to get the box dropped (which again, never went through) The workshop I took it to said they sprayed some lube on a few bits (sounded to me as though they only did the pivot boot thingy which squeaked a little sometimes like rubber on rubber), but they may have lubed the thrust bearing too? if that's both possible to do, and possible without droopping the box... So yeah Sorry Usamah, can't really help. Though if you understood what I was saying exactly and you're having the same sound...and not all the time, it might be the thrust bearing too. If you can drop your own gearbox out, have a look, otherwise the labour won't be cheap to have a look. I was advised to just deal with it until it gets worse, because if my suspicions were correct, when it finally eats shit, a thrust bearing is rather cheap anyways. Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5233363 Share on other sites More sharing options...
Aleckr33 Posted November 10, 2010 Share Posted November 10, 2010 Also, recently there will be a very faint chirping/circulating squeak sound coming from the clutch area when idling in neutral, which disappears with even the *SLIGHTEST* touch of the clutch pedal... Sorry to bump up thread but this is all i could find.... Im having this squeaky noise coming from the clutch area as well, and as Trozzle said, with a very light push onto the clutch, the noise goes away.... what could this be? should i be worried? Thanks. Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5542872 Share on other sites More sharing options...
SkylineSky Posted November 14, 2010 Share Posted November 14, 2010 It will be your spigot bearing in the back of the crank or the throw out bearing is shot.... that is all, but you will need to take out the gearbox to do both.. Remember to soak the new spigot bush in oil before installation. Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5549683 Share on other sites More sharing options...
Aleckr33 Posted November 17, 2010 Share Posted November 17, 2010 It will be your spigot bearing in the back of the crank or the throw out bearing is shot.... that is all, but you will need to take out the gearbox to do both.. Remember to soak the new spigot bush in oil before installation. Thanks for that... any harm/danger leaving these alone for now? or should i do something about it now? (looking at buying a new clutch but not sure) Cheers Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5554597 Share on other sites More sharing options...
SkylineSky Posted November 20, 2010 Share Posted November 20, 2010 If the noise is only when the car is hot then it is not too bad, if it does it all the time then you have to get something done now... you wont need a new clutch unless your one now is shot.. Link to comment https://www.sau.com.au/forums/topic/313592-grindingrubbing-sound-coming-from-clutch/#findComment-5558238 Share on other sites More sharing options...
