When riding the clutch, particularly up my driveway, it will frequently begin to make a horrid grinding/drilling sound. I've noticed that if I push the clutch in, then attempt to go again, it just starts making the sound immediately once more. The only thing that will stop it from happening when I try to move again is if I let the clutch out for a few seconds in neutral. It also will occasionally (depending how long I allow it to make the sound) give off a strong burning metal smell....similar to an actually clutch smell, but distinctly not.
Also, recently there will be a very faint chirping/circulating squeak sound coming from the clutch area when idling in neutral, which disappears with even the *SLIGHTEST* touch of the clutch pedal...
Could this indicate a problem with my thrust bearing? The clutch is only about a year old, and has only done just under 20,000kms. I have only ridden it twice at about 3,000rpm for a second or two by accident, trying to get out of stupid traffic...though this smell is different to the above one. Otherwise, I am very easy going on the clutch itself, particularly changing gears. I wouldn't expect it to be damaged from use or worn out, which is why I don't think it's the cause.
The clutch is an Exceedy (I think heavy duty) organic
Thoughts?
yeh my money would be on the release bearing.
Thoughts?
$800 will get you a full clutch kit replacement.
4 hrs labour is about the usual + bearing $40 if the clutch is ok. so say about half.
the thrust bearing itself will cost stuff all, the labour can obviously get a little pricey as your gearbox needs to come out
I don't anticipate there being an issue with the clutch, unless it is faulty. Otherwise it has received very little abuse whatsoever, and symptoms/troubleshooting is suggesting otherwise. At least that's some food for thought tho, thankyou. If the clutch is bung, I don't know whether I'll just leave it be for now, and get a good double plate and possibly new flywheel further down the track, or rip it out and sell it to my mate for sweet shit all...ehh we'll see, but if it's just the bearing then that's not much at all.
Thanks for the input :(
Pretty sure from what I've read the symptoms you're describing with the noise (with pressing clutch pedal) indicate more an input shaft bearing noise?
IE:
Foot off the clutch = noisy/rattling
foot on the clutch = noise instantly goes away
Input shaft bearing in gearbox is fked too Jrm, but I know that noise. It's the horrid grinding/drilling noise when I ride the clutch a little bit (1000-1500rpm) up my driveway that is the main symptom.
When I let my foot off at idle in neutral, it makes the sandy sound of the input bearing, but there's a slight chirping sound somewhere else. This goes away the instant I touch the clutch pedal and apply the TINIEST bit of pressure (not even depressing it at all, just enough to "load" or touch the thrust bearing)
I had the exact same issue with my old crappy NPC button clutch - it did not want to be riden at all.. Changed the entire clutch, pressure plate, release and spigot.
The clutch was worn badly from improper fitment, but not sure if it was that or the spigot that caused it. Either way do your self a massive favour and ensure that the idiot who fits it cleans the entire assemebly and bell housing of all grease, and use graphite powder for assembly instead. Demand it!!
Where did you take your car to get the gearbox checked and how much, having troubles with my box,
Cheers
  • 3 weeks later...
Hey Troy, I'm sorry to hear about your clutch issues, as you know I replaced the clutch for you before I sent it down when you bought it (can't beleive its been over a year!)
The clutch in it is a Exceedy Sports Organic with a upgraded pressure plate from a R32 GTR HD kit. All parts were installed brand new and correctly by my one and only trusted mechanic.
It sounds from whats written here, your slave or throwout bearing could be the culprit, as for the heavy grinding at low revs, thats sounds more than likely a gearbox gear issue, ie your Input shaft, syncros ?
What was the result of dropping the box?
  • 3 weeks later...
Didn't drop the box, and yeah Zac I'm not sure if I've worded things right, but it's definitely not the gearbox. Technically the internals of the box are more or less stationary when it happens.
Good thing is I don't think it's happened since I said I was going to get the box dropped (which again, never went through)
The workshop I took it to said they sprayed some lube on a few bits (sounded to me as though they only did the pivot boot thingy which squeaked a little sometimes like rubber on rubber), but they may have lubed the thrust bearing too? if that's both possible to do, and possible without droopping the box...
So yeah Sorry Usamah, can't really help. Though if you understood what I was saying exactly and you're having the same sound...and not all the time, it might be the thrust bearing too. If you can drop your own gearbox out, have a look, otherwise the labour won't be cheap to have a look. I was advised to just deal with it until it gets worse, because if my suspicions were correct, when it finally eats shit, a thrust bearing is rather cheap anyways.
  • 5 months later...
Sorry to bump up thread but this is all i could find.... Im having this squeaky noise coming from the clutch area as well, and as Trozzle said, with a very light push onto the clutch, the noise goes away.... what could this be? should i be worried?
Thanks.
It will be your spigot bearing in the back of the crank or the throw out bearing is shot.... that is all, but you will need to take out the gearbox to do both.. Remember to soak the new spigot bush in oil before installation.
Thanks for that... any harm/danger leaving these alone for now? or should i do something about it now? (looking at buying a new clutch but not sure)
Cheers
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
