I run a 5558 0.63a/r low mounted stock position on 98, 286rwkw at 16psi- was tuned on 18psi, wana take it up to as high as possible -is 23psi do-able safely and how much rwkw should I expect? No e85 -its a daily.
Theres only one other guy on SAU that I know who runs the 5558 on a 34 aswl- he made 392rwkw on e85 high mounted and with ffp.
Got a link to that result? I know of someone who made around 370rwkw with cams, FFP, high mounted etc but not other than that. Do you have those supporting mods, or stock manifolds?
That guy was Kurtis from central coast, tuned by Jez-black 34 sedan- up on youtube aswl, I think its on this thread too, yes I have the usual support mods but no ffp and stock mani, 40mm gate
Gates hanging off rear housing btw, plumbed back -no ghey screamer etc. 23psi please lol. JEM stopped at 18, said it was heating up. I have coated the intake pipes over engine in exhaust wrap and removed the coolant bypass thru throttle body (big difference in getting rid of heating and response, was surprised). Now I can easily touch the intake pipe past throttle body and over injectors with my hand after some high boost redlining runs lol.
Yep that is who I was talking about too, except he made 372kw. I suspect your stock manifolds will quite quickly start making getting any more power on pump gas quite a bit harder as you start pushing past the point you are at now
  • Like 1
I know. Im just really really hoping to push a smidge past 315-320rwkw like stao has done with his various turbos- I'm after the kick in guts feeling. Whats the highest boost a stock RB25 on 98 has seen safely? I havent seen past 23psi on SAU.
Thats around the limit really of boost on 98 as things start getting hot and detonation starts unfortunately. If not interested in e85 id suggest a water methanol set up. You shojld see close to what you want in power wise with w/m
I can't know for sure, but I know I wouldn't have the confidence to book a dyno tune hoping that much power at JEM on the stock exhaust manifold and a .63a/r housing personally. Remember Stao runs his cars on a hub dyno, and uses a Brae exhaust manifold... one way or another it is quite likely to make things much easier to make that kind of power, especially as the boost gets up.
I'd expect a PT5558 should be able to flow a bit better than a GT3076R - but you'll need the whole setup to be up to the standard of making that power on 98.
I did consider wmi since its a daily, but seeing as its not popular I rang up n spoke to Mark from Unigroup, hes not a fan of it either and said he wouldnt bother with it, said theres a few things that could go wrong if not setup right yada yada
I know my stock mani and 98 fuel is the limiting factor here, but stao was making good power well past 300rwkw on stock mani before he got the Brae mani, what I didnt know was that his is a hub dyno lol, so maybe thats why.. What are your thoughts on wmi Lith, yay or nay, I have read the threads btw, and remember Kurtis was also on the 0.63a/r 5558, but he had a aftermarket mani
You need to remember Stao is not running the same turbo as you. You shouldn't be comparing what he got unless you are running the same turbo.
In your case the turbo has a much smaller exhaust housing to give you the spool effect you are after. Staos turbo is running a larger housing which will help fend off detonation.
In my own case 23psi was also the limit of 98. I was getting ping at that level.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
