I run a 5558 0.63a/r low mounted stock position on 98, 286rwkw at 16psi- was tuned on 18psi, wana take it up to as high as possible -is 23psi do-able safely and how much rwkw should I expect? No e85 -its a daily.
Theres only one other guy on SAU that I know who runs the 5558 on a 34 aswl- he made 392rwkw on e85 high mounted and with ffp.
Got a link to that result? I know of someone who made around 370rwkw with cams, FFP, high mounted etc but not other than that. Do you have those supporting mods, or stock manifolds?
That guy was Kurtis from central coast, tuned by Jez-black 34 sedan- up on youtube aswl, I think its on this thread too, yes I have the usual support mods but no ffp and stock mani, 40mm gate
Gates hanging off rear housing btw, plumbed back -no ghey screamer etc. 23psi please lol. JEM stopped at 18, said it was heating up. I have coated the intake pipes over engine in exhaust wrap and removed the coolant bypass thru throttle body (big difference in getting rid of heating and response, was surprised). Now I can easily touch the intake pipe past throttle body and over injectors with my hand after some high boost redlining runs lol.
Yep that is who I was talking about too, except he made 372kw. I suspect your stock manifolds will quite quickly start making getting any more power on pump gas quite a bit harder as you start pushing past the point you are at now
  • Like 1
I know. Im just really really hoping to push a smidge past 315-320rwkw like stao has done with his various turbos- I'm after the kick in guts feeling. Whats the highest boost a stock RB25 on 98 has seen safely? I havent seen past 23psi on SAU.
Thats around the limit really of boost on 98 as things start getting hot and detonation starts unfortunately. If not interested in e85 id suggest a water methanol set up. You shojld see close to what you want in power wise with w/m
I can't know for sure, but I know I wouldn't have the confidence to book a dyno tune hoping that much power at JEM on the stock exhaust manifold and a .63a/r housing personally. Remember Stao runs his cars on a hub dyno, and uses a Brae exhaust manifold... one way or another it is quite likely to make things much easier to make that kind of power, especially as the boost gets up.
I'd expect a PT5558 should be able to flow a bit better than a GT3076R - but you'll need the whole setup to be up to the standard of making that power on 98.
I did consider wmi since its a daily, but seeing as its not popular I rang up n spoke to Mark from Unigroup, hes not a fan of it either and said he wouldnt bother with it, said theres a few things that could go wrong if not setup right yada yada
I know my stock mani and 98 fuel is the limiting factor here, but stao was making good power well past 300rwkw on stock mani before he got the Brae mani, what I didnt know was that his is a hub dyno lol, so maybe thats why.. What are your thoughts on wmi Lith, yay or nay, I have read the threads btw, and remember Kurtis was also on the 0.63a/r 5558, but he had a aftermarket mani
You need to remember Stao is not running the same turbo as you. You shouldn't be comparing what he got unless you are running the same turbo.
In your case the turbo has a much smaller exhaust housing to give you the spool effect you are after. Staos turbo is running a larger housing which will help fend off detonation.
In my own case 23psi was also the limit of 98. I was getting ping at that level.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
