If the 32 setup is anything like the 33 then it's not very hard at all, put one in mine a couple of weeks ago took about 15 minutes to do the actual pump swap and another 30 trying to undo/do up the stupid screw ring :unsure: . Was a bit fiddly getting everything in/out of the tiny access hole but overall only some common sense and reading of SAU was required.
thanks mate, yeh it doesnt look to hard its just more or less the i dont wana screw it up factor ;)
i think ill give it a crack on the monday and see how i go.
do i need a tune after the fuel pump install?
If the 32 setup is anything like the 33 then it's not very hard at all, put one in mine a couple of weeks ago took about 15 minutes to do the actual pump swap and another 30 trying to undo/do up the stupid screw ring :cool: . Was a bit fiddly getting everything in/out of the tiny access hole but overall only some common sense and reading of SAU was required.
FVCKEN OATHH!!!!
My X-Trail took me days! Just couldn't get the frekin thing to budge!
Hammer and screw driver on the tabs ended up doing the trick...
Yea its pritty simple I did mine a month ago. Do not use the filter it comes with as it is to short and dont get the inlet and return hoses mixed up like i did. hehe. Try it yourself you can't really do major damage its just a fuel pump. live and learn :cool:
Yea its pritty simple I did mine a month ago. Do not use the filter it comes with as it is to short and dont get the inlet and return hoses mixed up like i did. hehe. Try it yourself you can't really do major damage its just a fuel pump. live and learn :D
woops i did use the filter, the car has been idling a bit rough since the install. I'm getting it tuned tomorow (nistune) so i can find out exactly whats going on though.
Its most likely the filter.
To have a better look, I would remove the fuel inlet on the rb and aim it into a bucket - switch the key onto on and you should hear it prime (listen for a high pitch sound) and immediately fuel should come out consistently for a short period. If it doesn't seem to be consistent change the filter - go to Nissan and get a new one.
You herd back from the tuners?
Goodluck
Goodluck
thanks mate, yeh got it back from the tuners and its all good now, i had the afm changed with a z32 at the same time, so that could have been causing the bad idle.
He said it pumped in plenty of fuel and the car runs heaps better now :ninja:
Tune not required, it's also a good time to change your fuel filter if it hasn't been done in a while, was surprised how blocked mine actually was. Genuine from Nissan set me back 40 bucks.
time for me to get a fuel filter for the 33.....cheers for letting me know the price of it :/
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
