As in topic wanting to see what jap exhusts you guys are running for r33 that are relatively quiet and I dont mean quiet as in stock but not ridicoulously loud so prob up to 95db as I dont want to go purchase one then to find its pretty much the same level as the one I got now. epas are on the rise these days and cant be bothered going back to stock all the time
Yeah I was looking at the trust since people are saying the kakimoto and stuff is pretty much like stock, how do you find the trust quiet enough to not get as much attention?
Have the Trust PEII & recon you would like it. Nice on idle, definitely not like stock but not stupidly loud...
Then as you really start to rev it up she goes wild! From what I have heard one of the more sedate jap exhausts
I've got a 3" Blitz Nur exhaust. I won't recommend it for your purposes. Has a fair bit of low rpm noise. I love it on full noise but have always considered changing for something with a little bit less noise when daudling around.
Luke
yeah might give it a go, I love the loudness of my exhust at the moment and the drone donest bother me just cbf coppin epa and having to take turbos ecus injectors etc
i have a 3.5 bee-r cat back, and it is loud (came with the car when i bought it). drone heaps. dont get it even look into it. i want to downsize or switch exhuast to something that produces a more RB burble.
you are from melb i see. i'd be happy to give you a ride if we happen to be at a meet sometime. although there are a lot of guys running the trust catback so you wouldnt have too much trouble finding a car to listen to
Ive got a 3" stainless X-Force exhaust with the bellmouth front pipe and its really good.
Gives really good results and sounds good, in no way too loud. im very tempted to put a decat pipe in actually give it a bit more grunt.
And yes im aware its not a Jap exhaust but still worth checking out, can hear the turbo spooling waaaay more now too sounds good as.
Edited by Rav3nNZ
i had a Jasma / 5 zigen 3.5" cat back & front pipe (with a bellmouth dump) on my previous 33, was very quiet down low but gave a nice scream in the higher rev range. Measured 93db @ 3500 rpm (from when i went through pits for inspection)
notice this with a lot of the Jasma exhausts that the cars come over with from Japan, they're not overly loud.
ive got a 3inch 'drift' exhaust, stainless steel from the dum, but running stock cat.. i personally think its loud, but cops dont notice my car so it must be qiuet.
i put in the silencer/resinator/restrictor in the tip of the canon when i want a qiuete drive.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
