Can someone cast some light as to why cops in Perth have nothing better to do than pull over performance cars for the most piss weak reasons and continually harass the drivers of these cars for no apparent reason as well.
Long story short, was driving along in East Vic Park doing the speed limit and what do you know, a marked car goes past and instantly turns around to pull me over. Their excuse - my window tint was too dark, what a load of f**king bullshit!!
As I don't have to say anymore, they stickered my car.
I took it over the pits at Welshpool and as I expected they picked the shit out of it. Just some of the faults they reckon are -
1. Too low - need 100mm clearance, which it has but the exhaust can is a little lower by 15mm WTF?
2. No load rating stamped on the 255's on the rear
3. Front mount Intercooler installed and as a result I had to remove the front bumper support. The intercooler is like a structural member and much stronger than the piss weak piece of flat steel that it replaced.
4. No battery box for ventilation
If anyone knows of a mod or a bracket I can fit so I can keep my front mount Hybrid Intercooler would be great.
Ok enough whinging
If it has Tyres or Tits
Its gotta be FUN!!!
https://www.sau.com.au/forums/topic/313956-conniving-canary/
Im not suprised, my car got a yellow for only 1 reason - the lowest point on my car (my dump pipe) was 90mm off the ground, only 10mm off the legal limit
funny thing was, i gave way to him as he passed me at a round about and then later down the road, around 100m, he stopped at a bus top, waited for me to pass, and then sped up behind me, right up my ASS.. then sirens come on.. im thinking..... wat the f**k man, ur kidding me.....
then hes like, this is a random license and breathaliser check, im like bullshit! (in my head ofcourse) acted all nice and polite, and he still slapped on a yellow
some cops really have their priorities ALL WRONG, anyone who challenges me on this should be shot!
I love these.
1:
The lowest point of your entire car and ALL of its equipment must be above 100mm.
This is not just to stop you from looking like a jack-ass, but its practacle.
2:
What cheap ass brand tyres are they ?
3:
Sorry buddy, but your intercooler is NOT stronger than your crash bar....your intercooler was probably installed for aesthetics and power you don't really need. The crash bar is there to save you, and your car. Again, don't do shit the cheap way - install the intercooler properly without cutting / shutting, and you have no drama's. If you need to cut the bbar to get it in there, the intercooler is too big. You don't need an intercooler too big to fit in there without structural modification.
4:
This is a simple ADR ... no comment.
Hmmmm, battery box? Now I have to admit, this one has me worried and a little confused. What does this actually mean in the context of having the battery in your boot? Mine is just sitting on a plastic dish (the one that came with the car) and clamped down (like it was when it came with the car). Is this stickerable?
R33's came with special batteries which allowed a tube to be plugged into the battery. This tube then went down thru a hole in boot and out under neath somewhere. This allowed the battery to ventilate. If you have changed your battery to an australian one, then i doubt it came with this modifcation on the battery.
There is also vents in the boot it self, bottom drivers side in the corner.. Take a look. Im sure that these are there due to the battery being in the boot.
I am running a jap spec battery so ive managed to keep that tubing. IF i was to go Australian type battery, i would just get a dry cell which doesnt need ventilaton as far as i am aware... =)
Edited by br3ndan
This.
why do tools like nic comment crap like that?
its like total cop talk
Legality says the car has to have 100mm clearance...which it does EXCEPT for the exhaust which is 15mm low. Sooooo it actually doesnt have 100mm clearance?
All tyres have to have load ratings on them.....his tyres do not.
To cut or modify a main structual part of the car is not allowed. Never has, never will....so why is it a problem that they picked that?
Not sure why you thinks its 'total cop talk'.
+1
Keep your car legal, it's not that hard.
15mm difference in height isn't even noticeable visually, but it is illegal. So just get your car raised 15mm, it will look exactly the same but will be legal. Not a big deal
If your car doesn't have 100mm clearance, you won't make it over the pits, literally.. there is a lip on the edge of the pit you have to clear. Stupidly low cars are silly anyway, best thing I ever did to the skyline (other than the 3L :)) was raise it up off its' balls. Handles better, better bump steer characteristics and no longer had to fear speed bumps.
Edited by bubba
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
