Hey guys,
I'm just connecting everything up to my stagea engine in my R33 GTS4 and am having a problem fitting in the oil pressure sensor plug. The plug appears to be to big for the slot. I have got this engine from a wrecker and am thinking he has pulled the standard one off and placed another as it seems impossible to connect. Im just curious if the sensor just goes to the gauge and nothing else and if i can do any harm driving with it unplugged. If it does its not a big deal as i still have the sensor from the de.
Thanks.
LOL you guise! :)
P.S. MrMassive, there should be a hex on the underside of the sensor, can't remember what size, I pulled mine off on the weekend but I had two sensors (stock and aftermarket) on a T-piece and they were all different sizes.
Edited by bubba
The reason because they are different is because stagea s1 only have a oil light.
Interesting, my s2 only has an oil light aswell. I'll be putting that sender/gauge off the 30 into the bus soon so cheers for that :woot:
Edited by bubba
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
