I've just flushed/ bled out my brakes as they were a bit ordinary at the pedal and after reading posts on here I've used Castrol DOT 4 Response-silver bottle-only to read on the brake fluid reservoir cap as I put it back on-in damned English so no excuse DOT 3 FLUID ONLY.
Ah Hem :P
I've used two full bottles of new fluid on the job so there would be very little, if any, of whatever was in there before left in the system , I ran each corner until the new fluid was through then a couple of pumps more for good measure.
My question is do I now need to go back and bleed/replace the DOT 4 with DOT 3 or suffer dire leakage consequences or worse if I leave the DOT 4 in ?
The brakes bye the bye are now as crisp as Bingles nipples on a cold Bondi morning.
https://www.sau.com.au/forums/topic/314306-wrong-brake-fluid-eeeeeeeek-or-ok/
no dot 5 is the silicon based fluid
question what would happen if somebody did use dot 5
would it eat away at the seals and or hoses or is it just because of the fact it dont absorb water
doesn't absorb water. the water will collect in your calipers and turn to steam, giving you brake fade at lower than expected temperatures. plus it'll start rusting your calipers having water in there.
dot 5 in a road car is a bad idea, use dot 4 or dot 5.1 in a skyline - dot 4 is more than enough for the street unless you're being an idiot. for track or mixed duties go 5.1 for peace of mind.
The dot 4-600 range of fluids is as good as you need & it is easily available.
Try the Motul RBF 660 & even the PBR (?) stuff.
The 600 is its (dry) boiling point in degrees F. Which is better than the dot 5.1 fluids.
Hence there is no need to mess about with the 5.1 nonsense.
Edited by djr81
IIRC;
Motul RBF600 boils at 310degC and costs around $25-30 per 500ml
Nulon Extreme performance boils at 280degC and is around $9 per 500ml
YMMV but for a street car the Nulon should be fine.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
