I've got an R31, and soonish I'll be dropping in a N/A RB30DE, I plan to use it for circut racing and a daily as well
I've been thinking of converting it to AWD using parts from an R32
Anyways, does anyone think that this would be possible or worth it?
feel free to share extra thoughts on it
https://www.sau.com.au/forums/topic/314336-r31-rwd-to-awd/
how fast do you want to spend?
Easiest way would probably be to weld in a 4wd front subframe, gtr or gts4. And the front upright knuckle thing, mod the tunnel to fit the transfer box.
You could probably keep the live rear axle if you could find the same ratio as the front diff you use.
Do a search on google for full race motorsports, they make turbo manifolds, The owner Geoff, has done a s14 with gtr running gear. I believe it was just a bit of cutting and welding, but the s14 is closer to the r32/33/34 chassis than the r31
https://www.sau.com.au/forums/topic/314336-r31-rwd-to-awd/#findComment-5160585
The cost of converting the R31 to AWD will easily surpass the cost of an R32 GTS-4 maybe even an R32 GT-R.
If you need a 4 door R32 GTS4 could be a viable option.
But if your budget is huge - It will be definately different.
https://www.sau.com.au/forums/topic/314336-r31-rwd-to-awd/#findComment-5160629
not worth it. will probably only be slower around a track with the poor old NA RB30 (even with a twin cam head) dragging around all that extra weight. Far better ways to spend that money if your goal is to make it faster on the track
https://www.sau.com.au/forums/topic/314336-r31-rwd-to-awd/#findComment-5160921
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
