  N1GTR said:
5's and 7's yes, 9's no
Ever driven a stock supra twin turbo? Im certain 9's on a 3L would feel the same, its too responsive and feels like it seriously lacks top end
7's, build rb26/30 with 260 cams and lots of boost. Try catching that on a hillclimb!
you cant beat the stock supras for response, full boost at 1500rpm then a bit of a surge around 4500 where the second turbo comes on.
  • Replies 378
Posted Images
Yeah that's how mine drives, but the first turbo is never off, the second you touch the pedal you can hear the turbo
I honestly think it's too responsive and the downside is that of course you can have too much response that power suffers
Still, I'd love to try some 5's and 7's on my setup or this hideck-it would be all kinds of fun :(
  • 1 month later...
A little...
Purchased a trust extension front pipe and a few other parts last week so I have everything thats needed to put the engine in the car now. The front pipe off being ceramic coated. The plan is to have the engine in the car and driving inside a month. I'll be posting pics of the entire process once it starts.
Cheers,
Ian
  • 3 weeks later...
I stripped out the engine bay of the car and removed the spliter and under trays yesterday in preporation for next week when the new engine will be fitted.
The car will be trailered to a workshop this tuesday and with any luck will have the new engine installed by thursday. Im having CV's rebuilt and a bunch of other small small maintenance things done at the same time.
The workshop doing the r&r are allowing me to take a few photo's along the way too, so i'll post up the installation images at some stage.
Edited by GTRNUR
Here's the latest...
The engine now has ceramic coated Trust 3" extension dumps bolted to the GTRS's. Ive not had the front pipe section coated yet as I'm not sure how much material will need to be added in order to get the pipes to clear the bodywork... factoring in the 20mm height gain of the high deck.
The car is currently on the hoist and will with any luck have the engine back in there by wednesday next week. The workshop is flat out at the moment, but thats ok.. I'm not in any hurry.
And here's a a few pics...
(sorry to see your selling all your stuff too Richard, epsecially the prime garage engine).
Im picking up the car from the workshop tomorrow morning. The engine is in and the basics are all connected. Only have intercooler/intake piping to do over the next few days and with any luck i'll be driving on the weekend.
The only fitment issue so far was the flanges on the trust dump pipes were close to the floor, so a a little bit of massaging fixed that. The Y pipe also needed about 2 inches of material added to get them low enough to round the bend and run parallel to the floor.
Here's a couple of pictures of the re-assembly.
Cheers,
Ian
Picked up the car today at 10am, and started putting it together again after lunch. All in all I made good progress, and the only things remaining to do to prevent a road test was that I didnt buy enough coolant, and I need a flange to finish the exhaust.
Re-installation of everything went really well. Im actually amazed at how well it all still fitted together. Ive taken a few pics of the re-assembly.
The return spliter pipe from the bovs bolted straight on with just a little more bending of the front hose required. The 80mm pipe from the twin turbo pipe to the intercooler fitted without modification, as the standard piping on the passenger side of the car was plenty long enough. The tape line shows how much of the pipe actually was still inside the rubber hose.
Getting the airbox back in was a little tricky, as the air supply hose to the front turbo has to be compressed a little. The spring in it prevents it from colapsing. I always have trouble getting that hose back onto the MAF sensors, so I dont think it was any more difficult than usual.
The airbox bolted back in place with no alterations. Standard cold air scoop installed for the moment. I'd like to source a nismo one perhaps one of those fancy gruppe carbon air boxes for it down the track.
Drivers side I had to cut and insert 60mm of 80mm tube into the return hose. The extra length required here was 25mm.
New billion hose kit installed un-modified on the pwr radiator installed, no problems. If anything I could hace shortened the top hose about 10mm as the height puts it closer to the top hose connection on the radiator.
I did actually start and run the engine for all of 5 seconds. Electrically everything worked, and oil pressure was good. Still have plenty to do before doing a road test though. Hope to be able to take it for a test drive on the weekend, and I'll be booking some dyno time mid next week to do the engine run in and more testing. I'll be taking video of the whole process.
That is all.
  zebra said:
I love how it looks dead stock but is hiding 3L and the engine numbers match :blink:
Vehicle must appear to be stock... Monster Garage! That has actually been a part of the goal from the start, as per what we are told of the RPMGTR RB29 apparently looking stock under the bonnet. If I can do the same and make 450awkw, well I think I will have really achieved something.
Speaking of achiving, the car is now running. I finished the last of the exhaust mods this afternoon, started the car and bled the power steering. Then spent a few hours chasing a vacuum leak that continues to elude me. Im pretty sure that its the passenger side hot pipe hose that goes to the intercooler piping, and that I will be lengthening that pipe a little after all.
Here's a video link of the engine running. Throttle response seems nice too, especially considering its runn a tame ~25 degrees ignition when the throttle is cracked open.
http://www.youtube.com/watch?v=viAUjT4sNsQ
The engine is now running with a power fc, and you can see that from the tracking when I rev the engine and close the throttle the airflow still remains high indicating the air flow sensors are still seeing airflow, so it over fuels the engine and nearly stalls it out.
Unfortunatly ive got a full days work tomorrow so im not too sure i'll be chasing this hickup tomorrow afternoon, or if it will be a weekend task.
Cheers,
Ian
Standby... fixing the sound...
Yes its Beer Baron's old R34. I nearly said havent changed much on the car... then I re-thought that statement!
Edited by GTRNUR
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 馃槅 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 馃檪 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
