Well I bit the bullet and this Kakimoto cat back arrived last night! Unfortunately the quick install saw a snapped stud last night.... typical - two bolts to install and one broke!
will fit it today when I get a chance and post some pics and feedback
The quality is awesome, and im sure its alot lighter than the massive factory item!
Ben.
I would be interested in hearing if anyone else is getting a dump pipe and front pipe made up to fit an aftermarket exhaust. So there is a possibility Westside has a flange to fit?
I think i have westsides flange. i did most of the footwork to get em off the ground there. i had about 10 lazer cut in the beginning after buying the hack job of a flange from liverpool exhaust.
get together and get westside to make a bunch more, i wouldnt mind my one now haha
Ben.
Mmmm... Kakimoto N1 Hyper Mega.
Very pretty indeed. Can't beat JDM aftermarket gear for quality, particularly for exhausts :D
Out of curiosity, who did you get it in through and how long ff it take?
will be interested to hear you comments on how you find the exhaust inside the car as that is a pretty small middle muffler.
But it does look nice.
Should be around the 95dB mark at the tip if I recall correctly.
Will sound awesome though.
Youtube vid please! :)
Edited by iamhe77
Well bolted it up today after grinding a stud off and punching it through the original front pipe... why is nothing simple when it comes to cars?
But it was well worth it! the kakimoto isnt too loud, but has a great low down grumble at idle, and screams very nicely up top!
Its definitely louder than a Legalis, but i would like to think the kakimoto flows a lot better - there is a noticeable increase in power, which surprised me quite a bit. I didnt expect to see much improvement until dump/front and cat were done. It seems to pull a bit more down low, and alot more up top than the standard exhaust.
I got my brother to do some drive-by runs on quiet country road, and it sounds great from outside :)
Ill get some pics of it installed over the next day or so - I dont have a video camera - so not sure if i can record any sound :D
It sits a little low doesn't it? You will have to be careful with that.
And that's why I decided not to get a Kaki because it sits a bit too low for my liking, especially when my car is 2.5" lower. But if the height wasn't an issue, I would've bought one of these exhausts as I've used Kaki on my other cars.
For flow wise, it will beat the Fujitsubo no doubt as it doesnt have a mid muffler.
well the test was the driveway to my unit. I would scrape pretty heavily with the old exhaust, and while the kakimoto still touches, its not as bad as the stock. same goes with the local supermarket carpark, all the bumps there would slightly scrape and now it clears it!
I think it sits lower at the tip and inline with the rear axle (but because there are wheels there it wont scrape there very often...)
  • 3 weeks later...
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
