hey SAU'ers, nissan noob here.
i have just engine swapped a rb20 into my silvia. and i have a slight problem
the cyclinder 5 is not working. now my question to you guys is what is a good way to check wether my coild pack needs replacing or the injector.
i have yet to swap around coilpacks, i have just got new spark plugs but the old ones seem to be good (blitz brand and good colour) except for cyclinder 5 which is black.
from this observation am i alright to assume that there is fuel getting in but no spark occuring.
the car is pulled apart at the moment and i thought id post on here before jumping into it.
there is another thread just like this one and i got some good info from it, but just wondering if my assumption on the spark not firing is correct judging that the plug itself has tuirned black
thanks for any replies
https://www.sau.com.au/forums/topic/315153-coilpack-or-injector/
Easy test. Remove the coilpacks plug from cylinder 5 and fire it up. If the car runs the same (like crap) that's your problem
i did this already to work out that cyclinder 5 is the one with the problem, as i removed plug and the sound did not change.
but is this for sure mean the coilpack is damaged ? couldnt it be fuel injector
A black spark tip usually signifies poor combustion, rather than no combustion.
Do you have compression in #5? Poor compression could cause poor combustion of the air/fuel mix.
Clean #5 plug, to make sure it will fire correctly (if it's going to fire). Swap #5 coil with another cylinder, and observe which cylinder now has the problem.
i like how you say "just" and a "slight" problem
dude youve done a complete engine swap., there could be a million things wrong
check basics, recheck your wiring , plugs, run stock ecu diag, check all wiring, check all sensors
thanks for the help guys
to list iam going to do a compression check first before anything and then a coil pack swap with the other cyclinder. and use the new ngk plugs i got.
i checked the wiring today, and iam about to do a ohms test on my 5 cyclinder coilpack so i will post results, if this is even possible lol.
Blind_elk: thanks for that info, i will check compression asap and coil swap. atm i just wanna kill myself, i broke the peice of shit connector ontop of coil 4 lol. so i gotta get one of those and solder it on
paul r33 if your who i think you are, thanks for all the topics you had. i read alot of your posts, never thought id ever talk to you lol.
iam usually on nico forum, and they refer to most of your posts from that website you had. they love RB's
i have done stock ecu diagnostics, returning a code 55. so yeah no help there from stock ecu. if it was wired wrong it would return what error but ? ignition ?
thanks guys.
edit. how bad is it ive been driving the car for a while, about 4 days? ...and kinda drifting everynight for 4 nights since ive finished the swap
didnt even really notice because i daily a wrx with a exhaust LOL. my hearing is already quite impaired from this lol
Edited by hisoka
If you've got an ignition lead just plug it in between the spark plug and shove the other end in the coil, and use a timing light on it, if its flashing you have spark. Could also unplug the fuel pump, start the car until it stalls, then take out the spark plug and ground it against something while turning the car over. You should be able to see a spark. Otherwise its likely to be a fuel issue.
lol thanks man. why didnt i think of this.
will do this
hey guys. for future reference to anyone who thinks they have a coilpack gone and have not been able to swap with other cyclinder.
the easiest way, is to get a multimeter and do a ohms test on positive and negative. the reading will be open line.(no resistance)
i can confirm this works, as today i found out that my coilpack has no resistance. this is the damaged coil pack. my working one
has a resistance.
thank you guys for help. and now heres another way you guys can tell people to check packs, it takes 10 seconds. cheers
Edited by hisoka
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
