I don't think that this belongs in the epa section of the vic forums, as i'm looking for opinions of ppls from past experiences.
I curious if my exhaust exceeds 90db. My set up in my R33- i'm running stock pipes from the turbo to cat- 3inch high flow cat (catsco)- 3inch turbo back exhaust (hakimoto [not sure on the spelling]).
Today I went and got the exhaust lifted to ensure that my car is legal ride height and they didn't have a db reader. I'm currently trying to tidy up any loose end to avoid and surprises further down the track, not really looking for fines either lol
If ppl have facts of this issue, i'm keen to hear your thoughts.
Thanks
https://www.sau.com.au/forums/topic/315694-legal-db-of-my-exhaust/
well i just cleared my EPA last week. 3.5" dump which i then bolted a stock cat back exhaust onto and my reading was 87db
seeing as you have changed from the cat back there is no way you will be at 90db or under.
Two mufflers should be alright. It's a qualitative measure so I'll wait to hear the vid but you should be right. I've got one muffler and a hotdog, it's alot louder than stock and the cop didn't say anything about my exhaust when I got pulled over for inspection.
Where did you get your exhaust lifted? and what part can get tucked up?
i'm pretty clueless to this stuff..but last time I was at my mechanics getting other stuff made legal, i asked him if he had a wheel to measure ride height. The entire car was clear except the middle exhaust bit that hangs down right under where you sit, it just clips his measuring tool a little and gets stuck. is there anything that can be done about that or should i be looking at suspension, not exhaust?
You can get any part lifted up as long as there's enough space between the pipe and the chassis. They'll just put a small mandrel bend in either side of the part that is too low. Alternatively, if you have coilovers you can just raise the car a quarter of an inch lol.
Cheers Birds, I'll get onto that.. any recommendations of a place to do it though.
Peter where'd you do yours? And where are you heading to get the DB sorted out and tested? shouldn't a mechanic or a wide number of places have these? if so, i wouldn't mind knowing my own reading. keep us updated on the outcome.
Quiet alr33x you hellaflush fool.
Any exhaust place will be able to do it for you mate. Ringwood performance exhaust were pretty good when I got mine done there.
lol @ "Legalis", funny as name.
Its doubtful that if its aftermarket exhust it will pass the stock r33 cat back is pretty borderline to legal ranging form like 86-90 and thats real quiet so doubtful any aftermarket would pass , can come close though
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
