I have a R33 RB25DET VVT head on a rb30 with a GT35R.
At the moment it has stock cams and valve springs running @ 12 psi.
At what point will the standard valve springs need to be upgraded? I intend to go +20psi
What springs would you guys recommend?
Edited by Alf
https://www.sau.com.au/forums/topic/315776-valve-spring-upgrade/
I made 370rwkw @ 24psi (GT30), 8000rpm (RB25/sunoco104)
I know Guilt-Toy has also made 350rwkw/GT35 RB25/30 @ around 20psi...
Both were stock heads.
However that being said, there have been people who have had valve float below 300rwkw and 16-18psi.
So it largely comes down to the condition of the head before you begin proceedings.
I would say give it a shot, see what happens.
If you need them you do, if you don't - you don't :P
We have a standard neo head (just head studs and nitto head gasket) on a standard bottom end making 587hp on 25-26psi and the valve train is fine. As it has been said before, just crank the boost and power into it until there is a problem. If you do have the head apart for cams etc, then obviously maximise the opportunity and put some springs in there too.
actually i was up at around 374rwkw with stock head and stock cams. i ran up to 2 bar around 31psi on power cruise weekend and normally use 20psi low boost and 26psi high boost
i have some kelford 272 cams to install but i was told i NEED the valve springs to be able to use them.
so if you have stock cams you should not need valve springs unless yours are lazy etc etc.. also my head has done over 300,000km.s... 330k actually :thumbsup:
i never rev the engine past 7200rpm at the drag strip and 7000rpm limit on the street.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
