I just had a new battery installed so i thought i would reset the ecu...
i have to say i never had a problem like flat spots or bad idle but i found that now i have more bottom end, and very suprisingly the rev limiter seems to be kicking in just past 7000, which before used to kick in around 6500!!! :D
and it not as violent as it was before the reset...actually its quite smooth...
i am wondering if anyone had similar results from an ecu reset, or anyone know why this happened....
look forward to comments.
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/
i had similar results on my 32 as well. you basically reset the ECU so that it will relearn your driving characteristics again. i usually reset whenever i had any mods on the car such as air pod, exhaust, new oil change and even strut and sway bars. you will notice the RPM bouncing up and down a little but that's normal. run a search thru' the forums and you will probably find more comments on resetting the ECU.
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/#findComment-637310
Resetting has smoothed out things for me a few times.
After I've reconnected the battery I let the ECU learn things differently to other people do.
I start the car and let it idle for 5-10 mintues. First off it's a little high and sometimes it hunts a little. After a while it learns the idle and is perfectly smooth.
Then I'll turn the air con on and let it idle for about 5-10 mintues, again it hunts for a while then it's perfect. Then again with the air con on AND the rear demister on etc...
Then instead of taking it out and reving the crap out of it I just drive normal.
Works a treat for me.
J
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/#findComment-637470
interesting comments so far...
i gotto say when i did the reset about 2 weeks ago i didnt notice much difference, but today i made sure i stepped on the brake pedal about 15 times to make sure all power drained...whereas 2 weeks ago i only pressed the brake pedal about 5 times.....
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/#findComment-637576
Don't bother pumping the brakes, just hold the pedal down for at least 30 seconds.
What it does is closes the circuit to the brake lights, the lights will then suck all the remaining power out of the car, eg. all the power out of the capasitors etc...
So once the power is sucked out of all the capasitors in the ECU it will loose it's memory.
J
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/#findComment-637756
im a big advocate of resetting the ECU since i did it on my DR30 (FJ20ET engine)
my last car, S13, didnt seem to make huge improvements from ECU resets, mainly it did a bit wen i got full exhaust, and also wen i got big intercooler. but nothing major really.
but the DR! wen i got it it was running shit, misfiring like hell, seeming to hit the revlimiter as it tried to come on boost, hunting at idle, just running all shades of shite. then i changed the plugs (they were pretty worn out but not totally) and unplugged battery overnite and reset the ECU, and WALLAH! absolute perfection! revved rite from 0-7000rpm redline without a hiccup, didnt hesitate on gearshifts, and didnt hesitate on/off throttle.
it felt like a new car really just from ECU reset. but this is an old management system so its probably pretty shagged haha my mate said his FJ s12 did the same thing, wenever it got rough he just reset its ECU and it was perfect again!
also i accidentally overboosted mine to like 1.2bar and it made it go all retarded too so i had to reset to fix that. (0.9 is most i usualy run, or just under)
https://www.sau.com.au/forums/topic/31590-just-reset-my-ecu/#findComment-637849
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
