Hey guys,
Seeing as we have a 1/4 mile thread thought i'd chuck this up as its more of a real world performance benchmark and i'm intrigued as to what the quicker stags are getting down to
Its nice and easy if you've got an ecutalk or a boost controller that does 0-100's
use a format like this:
Model:
Mods:
Power:
->0-100 Time:
So mine is:
Model: S2 RS4S
Mods: Turbo back exhaust, constant high boost mode
Power: 137 awkw (from prev owner, was running 7psi but is now running 10)
->0-100 Time: 5.65 as read from the ecutalk (with a quite a bit of clutch slip)
Cheers, Tom
https://www.sau.com.au/forums/topic/315900-stagea-0-100-times/
So mine is:
Model: S2 RS4S
Cheers, Tom
O-100 in 5.65 - I should check your reading
Edited by RSVFOURUK
yeah my speedo does read a tiny bit under, but probably still a sub 6 sec time
did also launch from about 5k rpm
lets see some more times, most boost controllers have these kind of functions if set up correctly
Bear in mind RSFOURUK that most of the world uses km/hr not miles/hour. But it still looks a bit quick to me.
Yes sorry about that
The 260RS was supposed to do 0-60mph (100kmph is 62,5mph) in 6 seconds so 5.65 would be a fair bit quicker.
Another thing to keep in mind is that Stagea speedos read high... usually by 7-10% :(
Not sure how the factory measure their 0-100kph times, but a 0-110 speedo reading time would give a more accurate 0-100 real world time... if that makes sense :)
blazt tells me mine does 6.3 on a good slip launch from 4 grand . cat back front mount 0.65 bar . half a tank and my 100+ kg
are you going into third or limiting 2nd? could cut my time if i let it hit the limiter in 2nd
There's a program I've got on my iPhone that measures acceleration, braking, g-forces (on a skidpan or during acceleration/braking) and approximate power outputs.
It's called Dynolicious, here's a link...
I haven't had a chance to use it yet because I like owning a car and having a licence and dont' want to risk either of those by "practicing" on the road, so maybe at the next track day or skid pan day I'll try them out.
The gtech bangers are quite good, used to sell them and trial used one, was pretty close to the money on a friends tt 300zx we are talking about 5 years ago and have no idea what model, from memory they were about 400bucks to buy
Or just use the stop watch on your phone.
if you've got a digital camera that takes video you can use that, there are bits of software about that let you go through frame by frame and you can work out the exact point when you hit 100
let see some times ppl
mine was like 3.?? (cant remember exact number, but was measured with gtech) when i did it years ago with the old motor setup, it did a 11.1 @128mph on the gtech on same run (street tyres on the street with stock gtr manual box). 560hp at wheels, and pretty modified (too much to list)
Edited by unique1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
