Hey guys, A while ago i was reading a thread that had everyone's skyline pictures in it and there was one in particular that caught my eye. A silver R33, no rear spoiler and gold volk racing rims ( photo was taken in someone's back yard)
Anyway where can i find photo's of skylines to have a look over and get ideas on what to do when i get my next one?
Is there a thread here or a good website?
Thanks in advance guys...
Cheers
https://www.sau.com.au/forums/topic/31606-skyline-photos/
There are a few standard "looks" for the 33, whether it be stock, GTR look, 400R look, stealth wing look, big wing look, something else, or some mix of different types. i think stock is pretty boring
here is mine.. wanna get 400R sideskirts, and detail some more things in the engine bay. whoever says "marone sux" is full of crap, as i think they look great done up a bit, lot more reflective, etc.
a nice interior is important also. Looks much to bland stock!
https://www.sau.com.au/forums/topic/31606-skyline-photos/#findComment-637661
  • 3 weeks later...
Anybody know about the rear wing on tony?
Thanks for the comments guys.
I hardly even drive it any more due to some issues and the fact my workplace tends to be demolition derby for trucks and it's near a petrol refinery that leaves crap everywhere.
The car looks very different to those pix now. The rear wing is a Signal Auto drift wing.
Copies are available from Bodyform in Sydney and many other places I expect. It has to be matched with a high mount stop light. It is a defect to not have a stop light but that's a bit silly on a Skyline I'd admit. As if you can miss FOUR lights coming on.
T.
https://www.sau.com.au/forums/topic/31606-skyline-photos/#findComment-665716
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
