Well given you are melbourne, no.
The defects you will attract are not really worth the grief.
I mean yes the less you weigh the faster you go, but don't think by changing a bonnet you'll suddenly be even 5% faster. You'd have to remove 100KG's+ to really feel a difference IMO.
As for vents - do you have current cooling issues?
Vents help with cooling, however the dynamics of high/low pressure area's I've never really dug into
https://www.sau.com.au/forums/topic/316099-weight-redution/#findComment-5173892
ive been looking for a carbon fibre OEM style bonnet (so i can spray it the colour of my car) for my 33 for AGES. problem is the most common ones have vents in them.
some american car club did a test on a nissan sentra a few years back to get it from complete stock (16s 1/4 mile) to see how fast it would go with all its weight stripped off. from memory it ended up doing around 12s after removing every panel and part that wasnt needed which included chopping the roof.
https://www.sau.com.au/forums/topic/316099-weight-redution/#findComment-5174988
I had this idea a while back as well. It sounds like a great idea although the biggest problem is being a skyline you'll most likely be pulled over anyway "for the sake of it". As soon as they pop the bonnet they will see underneath and it will be pretty obvious that it isn't standard. Would be a fantastic idea in a true sleeper that will pass by unnoticed in the first place.
Luke
https://www.sau.com.au/forums/topic/316099-weight-redution/#findComment-5175023
Luke
i dont think they'd really notice. i'd spray the inside of the bonnet anyway, they would just have to notice the reo on the underside of the bonnet isnt there - most (if not all) wont pick up on that.
https://www.sau.com.au/forums/topic/316099-weight-redution/#findComment-5175168
I'd agree.
I think the 15-20odd kg you will save for a cost of $1500 on a 1400-1500kg car is not money well spent.
If you took 20kg out of a 700kg S1 lotus elise that might be a different story.
If its a GTR forget it, the bonnet is aluminium anyway and you are paying a fortune to save a few kg. The boot, spoiler and all hinges weigh a bit though.
https://www.sau.com.au/forums/topic/316099-weight-redution/#findComment-5191099
like
https://www.sau.com.au/forums/topic/316099-weight-redution/#findComment-5191339
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
