Great night guys, was good to meet you all, especially the grey R32 mafia :(
Will post pics as soon as humanly possible. Look forward to the next one. Feel free to add me on Facebook (real name Adam Forwood), just say you're from SAU so I know you're not some freak random.
  • Replies 87
I wont be able to make it for the cruise!!! Sorry girls :( I have to go ice skating with my motorbiking mates (go figure :()
Will try for the garage cafe though :)
Hey Charli, I assume that was you next to me in the Liberty coming onto the Eastern Freeway.
Sorry about not chatting to you, didn't want to snub you, but the light went green, you know how it is ... :(
Sorry about not chatting to you, didn't want to snub you, but the light went green, you know how it is ... :cool:
HEY!!! Thats ok I'm glad there was a witness!!! lol... So I made it for a little while. Was sad I couldn't keep cruising with everyone. Was trying to wave to R3DLNE but those guys were eyes on the prize only. This ice skating thing I ended up doing was actually kind of fun... the ice hockey looked better though... I recommend it!
Edited by charli
I finished work at 6:30..the meeting point time. By the time i got home and gotten ready = everyone leaving carwash and heading for the cafe
yer man...was hopin u come, coulda given me a run on the blvd :D next one i organise will be thursday again and 8pm. only did this one this day and time because it shuts at 10pm the cafe.
there was only one r33? bullshit. you people are weird
well only 2 ....but yes very weird...its the first time thats ever happened to me on a skyline meet up. Normally whales everywhere. :D
yay for 8pm tho....much easier for me to make it on time ;)
And Charli death defying maneuvers in white liberty had my heart in my mouth for a second.. I vote more chix at next one..... :)
yer man...was hopin u come, coulda given me a run on the blvd :P next one i organise will be thursday again and 8pm. only did this one this day and time because it shuts at 10pm the cafe.
Don't worry i will make sure nothing holds me back for whatever is planned next time. Oh and we have to do the blvd run still :(
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
