I have a r33 rb25det. I recently blew the turbo and replaced it with a high flowed and rebuilt rb25det turbo. Now the car is idling between 1200-1500rpm at all times. it Doesnt change whether its cold or hot and i have checked all vacuum lines, every gasket on the intake side of the engine, basically everything. I have since put my stock BOV back on and besides the front mount intercooler kit, pod filter and exhaust the car is stock.
As for boost control i am using just a vacuum line from the intake manifold to the turbo actuator.
Ive run out of ideas as to what it may be so any help would be greatly appreciated.
Thank you :P
Edited by tom_v
https://www.sau.com.au/forums/topic/316232-high-idle-problem/
Just found the DIY for "Aac Valve Cleaning & Idle Reset"
http://www.skylinesaustralia.com/forums/Di...nd-t110431.html
Ill give this a try and see how i go, i really wish it didnt get dark so early now, bring back day light savings! lol
I just finished cleaning out the AAC valve. I Disconnected the TPS and let the car idle. It sat at about 1200rpm as it previously was. i then turned the adjusting screw on the AAC valve to lower the idle. i got to about 950rpm when the screw was fully in. Im guessing it is still not right cause it should not be all the way in. Should i adjust it now on the ecu??
Also there are two plugs on the TPS, i did the adjustment with the grey top plug disconnected as when i disconnected the redy/brown plug it just reved very high. Was this correct???
Edited by tom_v
Ill check that its bled properly, it probably isnt, but would that really make it idle all the time at 1200rpm? Like even when its cold and first starts up?
the idle control valve has water running through it, air lock will cause it to do weird things.... S15's are the worst for it as the water runs through the TB... they will idle around 2500rpm if airlocked :D
Ive checked the cooling system, its all bled up fine. Im wondering if because its a high flowed turbo it may be pumping in more air then a standard and rasing the idle. Has anyone put a high flow on and experienced something like this?
Ive adjusted the idle by clamping off the pipe to the AAC valve and setting the base idle by adjusting the little screw on the throttle. I did this with the TPS disconnected then after setting it all, reconnected the TPS and switched the car on and off. It now idles at 900rpm nicely and the AAC valve adjusting screw is not all the way in... Is this ok? Ive listened and checked all vacuum lines, even checked by spraying brake cleaner over every line and did not get any reaction from the engines.
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
