Has anyone run 225/50/16's on standard R33 GTST rims. I think from memory they are only 6.5" wide, so in theory 225 maybe a bit wide. Just after some first hand reports for street, track, or drift cause the standard 205 are way too skinny. Just trying to keep stock look, I have a set of 18" Zivell speed rims that I run from time to time, but rather run standos. Thinking about Kumho KU36 as I reckon they are good bang for buck.
https://www.sau.com.au/forums/topic/316375-2255016-on-standard-r33-gtst-rims/
Street slow=Fine
Skids=Fine
Any speed type driving=Fail
My car understeers like crazy if Im pushing with them on, and dont even think of boost, unless sideways smokey action and steering with your throttle or hand brake is what your after.
They are OK for day to day going to work and thats it.
My 2 cents
Street slow=Fine
Skids=Fine
My 2 cents
I agree with all of that besides understeer.. My current set are Re001 225's all round and it's quite taily. Maybe just the way I drive tho :cheers:
205's feel very direct but ultimate grip level isn't fantastic and they look ridiculous especially from behind. 225's look much better but there is a LOT of sidewall slop. I found running 40psi to be reasonable, anything less is horrible.
225's for day to day fine, put 40psi in them unless you drive like a grandma and if you actually want to have fun then strap your 18's on.
If I had to choose for day to day driving I would still run 225's because the 205's just look retarded on a sports car. And yes, standard fitment options are 205/55/R16 and 225/50/R16.
I'm running 225/50 on s15 rims- they look waaay better than 205s and I didnt notice any deficiency in handling.
That being said, even with the old cheap Kumho 205s, I had no problems with straight line traction unless I dropped the clutch on launch. They were even good for reasonable 1/4 mile times!
your contact patch for 205 vs 225 is actually the same area, so straight line traction should be the same. the difference is the 205's are long and thin and 225's are short and fat, relatively speaking. it's the wider cross-section that helps with cornering grip.
unfortunately 225s have too much sidewall flex so turn in feels very vague. also once you exceed the traction boundaries the tyre moves about and again feels very vague, there's not a "limit" as such that you can treat with finesse but an area where traction comes and goes. yuck.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
