after getting everything ready for my new fuel setup
it dawned on me that issues with unused fuel returning to tank hot ,
could be aided by some type of cooling
i was thinking a small oil / trans cooler with a fan mounted to it might work
some thing like this
http://www.a1hiperformance.com.au/docs/pro...php?prod_id=335
im looking for suggestions / criticism so go ahead folks
what do you think?
Edited by shakotan-cefiro
https://www.sau.com.au/forums/topic/316491-fuel-cooler/
Except a car with 600hp willl heat up the fuel as it usually only needs 50hp of fuel and 5the rest goes round and round. I would say it isnt really an issue in a drift car, as they dont run for very long, and as rob said a good % of the fuel that goes into the rail goes into the motor, not round and round
https://www.sau.com.au/forums/topic/316491-fuel-cooler/#findComment-5178702
Waste of time match your fuel pumps flow rate to your power output with a safety margin of 30% and you won't have any issues with hot fuel.
1500hp twin turbo v8's...... idling around town with aeromotive 11102 's there is a whole lot of bypass.. hence why we use them. Application
http://aeromotiveinc.com/products-page/fue...&height=136
https://www.sau.com.au/forums/topic/316491-fuel-cooler/#findComment-5178766
using a cheap tranny cooler from super shit in the return line on my car. mounted it just behind the diff.
i dont see how you'd be getting hot fuel in a drift car tho, it takes a long time at light load for even a 044 to start cavitating, not like drift cars are at 1-2% inj duty for long
https://www.sau.com.au/forums/topic/316491-fuel-cooler/#findComment-5180674
Why the hell do you have two aeromotive pumps when 1 is capable of that horsepower. Why wouldn't you just you just stage the big pump and run an 044 as a primary? Surely a 1500hp car isn't going to be hanging around the streets for too long anyway
As far as formula's go. Multiply your injector size by the amount of injectors you have then add 30%.
Edited by rob82
https://www.sau.com.au/forums/topic/316491-fuel-cooler/#findComment-5180792
RE-READ my post "twin turbo V8's" ..... im referring to multiple cars hence multiple pumps....
you would be surprised how many kms one of them does, frequently driving interstate.
https://www.sau.com.au/forums/topic/316491-fuel-cooler/#findComment-5181158
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
