hey guys, just wanting peoples opinions on this quick motor build im going to put together before august, use it for a while whilst im prepping a built 30 bottom end
it consisits of:
- standard RB25DET
- top mount turbo manifold
-40mm external gate with 1.1bar spring
- GT30/GT35R turbo
- Forward facing plenum
- Atleast 770cc injectors
-Bosch 044 fuel pump
-Oil cooler kit
- 52mm alloy radiaitor
- Z32 airflow meter
tuning wise thinking i may get away with a nistune with the help of a SAFC??
Later down the track ill smash in 260 deg cams or may have enough saved to put them in when i add the above extras but was thinking if im running only 15 psi of boost standard cams shoild be alright??
(please correct of im wrong)
whatta we think?
Edited by Morgz32
https://www.sau.com.au/forums/topic/316716-build-opinions/
sounds like you have some cash to blow, i do not recommend you run a nistune if your planning to run a top mount setup, run an ecu that uses a map sensor as the inlet is something like 4" and an afm such as the z32 will be a restriction, it may even cause the car to stall/run like shit due to air reversion back toward the afm
get a pfc dj or something along that standard :D
if your running a standard motor, and 400hp will keep you happy, your probably going to like the response that the gt3076 has to offer as you will not be able to use the full potential of a gt35 on a standard motor
a pair of poncams will open up that midrange also giving the car alot more of an aggressive power delivery
my 2c, goodluck with the build
https://www.sau.com.au/forums/topic/316716-build-opinions/#findComment-5181029
yea i got abit saved up and continuing to do that until end of july i was thinking about the de jetro but again funds may be an issue... i wanna maintain a top mount set up with external gate.. the only hick up im having is a turbo choice... i heard/ thought 35R's are pretty responsive thats why i was going to go for it
with cams again see how much i got by the end of july and hopefully can scab enough up to buy cams as well 260 deg shuld help in the response department
https://www.sau.com.au/forums/topic/316716-build-opinions/#findComment-5181105
and snozzle like your saying with me not being able to use the full potential of the 35R forgot to mention that im using the 25 head on my 30 bottom end so i kinda wanna set it up so i can put the head and block together and then back into the car... should still be able to have fun with a 35R though??
https://www.sau.com.au/forums/topic/316716-build-opinions/#findComment-5181110
ohh your post said standard 25 though haha, well in that case, id also go for the gt35 on a 30 bottom end, have some 400kw+ of fun :D and traction issues......
i really do hope you dont run a nistune on a setup like this though!
Edited by snozzle
https://www.sau.com.au/forums/topic/316716-build-opinions/#findComment-5181308
Yea sorry about that aha completely forgot to mention that im putting the head on a 30...
well.... no....im not looking into power fc, haltech or motech only problem is finding one.. any ideas? tuning shops should stock them or be able to get them
https://www.sau.com.au/forums/topic/316716-build-opinions/#findComment-5181465
i see i see hmm i guess its probably best i call a tuning place like allstar or hyperdrive to see what they reckon...
so whatta we think of the setup in regards to turbo choice? will she be to laggy or pretty responsive with the aid of new cams?
https://www.sau.com.au/forums/topic/316716-build-opinions/#findComment-5182818
ive always known top mounts with such big intakes to be restricted by air flow meters, that is the basis of my reasoning
also, reversion can cause the afm to almost stall the car once u come off boost and back to idle (approaching traffic lights) if the intake pipe is relatively short which in most cases is
who knows, nistune will probably do you just fine, a friend of mine is making 400 with a nistune (not a top mount) and he is having no issues at all but in my eyes, a gt35 is a completely different setup as to a 'highflow'
https://www.sau.com.au/forums/topic/316716-build-opinions/#findComment-5182893
With an R32 you can use a GTR loom and ECU (daughterboards are the same) and then run 2x RB25 or even 2x Z32 afm's if you need to make that much power.
OR, there are other big single afm's out there (Ford Lightning is one I was recently put onto).
Personally, I prefer an airflow meter setup as it actually measures how much air is going into your engine and anyone tuning for a MAP setup should really be using an airflow meter to set up the maps otherwise it's just calculation and guess work.
I'd also prefer to have a system with ACTIVE KNOCK SENSING, no aftermarket ECU out there can do it that I've seen. Sure, PFC can display your knock levels on the hand controller and flash the engine check light at you, but Nistune will actually revert to different maps just like the stock ECU does when it detects knock.
https://www.sau.com.au/forums/topic/316716-build-opinions/#findComment-5183540
Either the bov is in the wrong place or it can't flow enough.
https://www.sau.com.au/forums/topic/316716-build-opinions/#findComment-5183543
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
