You need to disable the blow off valve so that it cant release the air. You dont need any specific type of pipe, but a metal pipe with a pod will give the loudest dose. Theres a huge thread on a vl forum about the different shaped intake pipes and what type of noise they make BAHAHAHAHAHA!
Unfortunately though I dont know how to disable the blow off valve as I am new to skylines.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184165
cool.. i kno how to disable the bov and add metal pipe... just not sure on what to do with the hoses once i remove the standard intake pipe..
any help would be useful...
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184198
Pff, everyone keeps repeating that crap about turbo chatter, 'dose' and compressor surge. People blow up their turbos by putting more boost into it, there still isn't any proof 'dose' has wrecked any turbos. Sure, in theory, engineering/mechanics wise, it should wear it more, but no more than a few % and far less than abusing it with high boost etc.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184234
Sort of depends on how much damage your willing to accept then.
There should be a way to quantify exactly how much the reversion slows the wheel down, but it probably wouldnt mean much unless you could whack it on a dyno for back to back comparisons.
Cheers,
Mitch.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184276
unbolt your stock BOV, trace it out on a rubber matt or plastic or aluminium, punch out 2x holes for the bolts, bolt back everything.. looks stock, flutters like a the sphincter of the universe :D
I did that when my stock BOV couldn't handle the boost but it got annoying so I replaced it with an aftermarket plumb back.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184297
It's called search, use it:
Dose pipe: http://www.skylinesaustralia.com/forums/se...te=%2Bdose+pipe
Hektik flutter: http://www.skylinesaustralia.com/forums/se...Bhektik+flutter
VL uleh: http://www.skylinesaustralia.com/forums/se...lite=%2Bvl+uleh
Sick flutter: http://www.skylinesaustralia.com/forums/se...%2Bsick+flutter
Seriously, it aint hard. Justy type in an adjective describing what you want "sick, hektik, fully, awesome, mad" and then an adjective describing the noise "flutter, dose, pidgeon, zututu" and you will find a billion threads.
*Sigh*
Edited by PM-R33
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184302
One will be BOV return. Don't need this when dosing.
Other will be breather return from cam covers. Either get a catch-can or put a fitting in your metal intake pipe for that hose to push onto...
could i just leave it....????? technically it wouldnt be going any where anyway.. would it..???????
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184372
No because it will be a vacuum leak since from factory one side goes to the plenum the other into that intake pipe (not to mention if you just left it open oil could drip out onto the exhaust manifold and start a fire). So either block the right side off or get a catch can or plumb it into your new pipe.
Edited by PM-R33
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184380
*Sigh*
love your work...awesome.
on topic...why you would want to do such a thing is beyond me. Sorry Mr Cosgriff :)
Edited by Swiper the Fox
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184539
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
