I was looking in behind my headlights and as far as I can tell everything looks to be in tact to refit my HID lights. The wires that go into the ballast have been cut and rewired to the halogen bulbs. The ignitors were neatly tucked in behind the headlight and seem to not have been tampered with.
Now what exactly is involved in reinstalling my original bulbs. It looks like some kind of spacer device has been put in for the halogens bulbs to fit.
Also, there is a yellow wire that is attached to the back of the headlight and into the back of the ignitor, is that part of the original wiring or to do with the halogen change?
Any help appreciated. Thanks.
https://www.sau.com.au/forums/topic/317189-xenon-hid-reinstall/
Well, undoing the 3 screws pulls out the globe mount and when it is out the spacer for the halogen bulb just pops out. Then the little wire clips that hold the bulb in, need to be bent to fit the Xenon bulb. I left the yellow wire attached, soldered the original wires back together and voila!
One HID headlight now working. Sure makes the old headlight look yellow!
Think I'll use crimps to join the wires on the other side as my soldering iron was struggling with these wires.
Also popped in my $4.45 "ebay special" SMD LED parking light, which matches the Xenon headlight nicely.
Do you know if it is possible to get the other bulbs that point down and wide to match up colour wise and match the whiteness of the Xenon? Or would it be too bright to have them both on you went the Xenon's anyway?
Not sure exactly what you mean, do you mean the lower part of the lights (High Beam and Fogs)?
It sounds like fog lights you are describing, that light up down and wide. The are the same bulb as the High beam, must just have two settings. Not sure if they are standard type bulb, or a unique to Nissan item?
It does seem a bit silly having Xenon low beams and Halogen fog and high beam. I guess the cheapest option is to see if you can find a replacment bulb that is the white colour of the Xenon HID low beam. There are lots of imatation HID's now, that look as white, and don't need the ballasts and ignitors etc.
I wouldn't mind a better high beam, I find it pretty ordinary!
I have the same problem with you, prdreilly. The car was sold to me with a halogen bulb head light. I too found some kind of spacer/adapter for the H3C halogen bulb. It's glued in place so Using a screwdriver, twist and lift will pop the spacer/adapter out. You will need the 3 part for the HID to work. My car came with the ballast, the clipped power pin but missing the Igniter. Got them from Ebay (which is not cheap) and the HID D2R bulb (price depend on what brand you choose). Connect the wire from the halogen setup to the power pin of the HID. I bought a 6000k but I think 4700k give a better lighting. By the way, I do have an extra PIAA 4900k H4 bulb for your high beam/spot light for sale. PM me.
Edited by FlyingEL
I was fortunate enough to have the Xenon bulbs and plug with cut wires for the ballast kindly put in my glove box after compliance. The ignitors were left in tact, so there was no need for me to buy anything, just had to cut the wires to the Halogen bulbs, pull out the spacers for the halogens and the bulbs (my spacers weren't glued, just pushed them out), then bend the wire springs that hold the bulbs in place, join the original wires back together (solder & heat shrink or Crimps), plug it all in and voila!
It is a bit of a fiddly job, you have to pull the wheel off, and the plastic guard liner to get to the back of the headlight, but I am pretty useless mechanically, so unless you are a total novice you should be ok.
No doubt this will be an incredibly dumb question BUT...
seen as the factory HIDs arent self levelling, corner sensoring etc can i just buy an aftermarket HID kit from our vendors for example and install that?
You could, but obviously it will cost you. If all your Xenon bits are already there, and all you have to do is put it back together, that is cheap to do.
Oh ive been wanting to refit my HID's but ive got no idea how to do it and dont really know much about headlights would u say its easy enough to do or should i take it to an auto elec?
First thing to do would be check that your ignitors are in tact, if not you have to decide if you can be bothered with the expense. Did they give you the original plugs that go into the ballast? If not, then you are going to have to chase up all those parts as well.
Huh? I though you have to take the whole bumper out and then you can get the headlights off. I think that will be easier but take longer time.
bumper and headlight is the correct way. you can get at it by leaning the inner guards out of the way but if the ballast has been pulled OUT then its a front off exercise. I do the simple way if I CBF'd ripping off the front.
If i did decide to go this route, would it be the H1 or D2R kit? I searched the OSRAM site and they say its D2R for HID but i thought id check :S
Yeah that's what I was wondering, thanks.
  • 3 months later...
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
