  • Replies 199
hi this is anthony . just baught te37 SL 18x10.5
awesome customer service. top bloke. very funny haha
thanks for the help il post up a pic when there on
cheers
  • 4 weeks later...
Price for matte black TE37 18x10.5 +15 please kind sir
(and what is the estimate waiting time?)
also, price for TE37 sl same size delivered, do you have stock?
  • 4 weeks later...
Hi Tom,
We need to order them in and I'll take at least 4months from time of placing the order.
What we have arriving in Flat Black that may interest you;
TE37SL
1set 19x9.5+22
1 set 19x10.5+22
A few sets 18x9.5+22
LMGT4 Gloss Black (This is a special order and only a few limited sets)
A few sets 18x9.5+12
Hi Tom,
TE37SL
1set 19x9.5+22
1 set 19x10.5+22
Thanks, can you please send me prices for the options you have listed.
  • 3 weeks later...
  • 4 weeks later...
